Autohelm ST4000+ rattle - SailNet Community
post #1 of 4 Old 10-07-2011 Thread Starter
I have an Autohelm 4000+ Wheel drive on my boat which generally works great.
However, when the pilot is disengaged (steering manually), under power, it rattles in the most annoying fashion Due to engine vibrations. This can be stopped by slightly lifting up the drive motor. Other than installing a bungy, there has to be away to stop the rattle and any input would be very welcome.
Many thanks in advance.
Matt
py26129 is offline
post #2 of 4 Old 10-07-2011
trantor12020's Avatar
maybe your drive belt has broken teeth or te clutch is not tension enough.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #3 of 4 Old 10-11-2011 Thread Starter
Ken
Many thanks for your response. I will take it apart after the boat come out of the water next weekend and lake a look.
Cheers
Matt
py26129 is offline
post #4 of 4 Old 10-11-2011
Quite likely a roller or two are broken within the drive ring.. btw supporting the drive motor with a zip tie works well... usually the wheel brake shaft is a convenient 'support' for this.
If you routinely remove the wheel for cockpit lounging then securing the drive is a problem.
Faster is online now
Autohelm ST4000 Wheel pilot LouAnn34 Electronics 27 06-14-2016 10:32 PM
Autohelm ST4000 Plus problems Outrageous Electronics 47 01-23-2015 07:20 AM
AutoHelm ST4000 jheitzman Gear & Maintenance 4 09-27-2011 06:01 AM
Autohelm ST4000 always going to the right. Sleek Geek Announcements and Suggestions Box 8 08-26-2011 03:54 PM
New England Autohelm ST4000 repair? McMikeJr Gear & Maintenance 2 07-28-2010 05:22 PM
