Old 10-07-2011
dillybar is on a distinguished road
Teak toe rail repair
Ive got an older Beneteau with a teak toe rail that has begun to split at a cleat.
The cleat that sits on top is still rock solid so I'm assuming the through holes for the cleat bolts weakened the rail in that area or let water in? The rail has a joint about a foot from the cleat and the split is now about 1/4" at the end.
My thoughts were to glue and clamp the rail back together and install a series of countersunk screws then cap with dowels and sand flush.
Having never seen the toe rail off I started wondering if there may be a locating channel cut into the bottom of the rail that I should know about before I start drilling. Or better repair ideas?
Any ideas from people that have done this type of repair before I start in would be appreciated.
Old 10-08-2011
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
If you go with countersunk screws then get teak bungs for plugging the screw heads.
Old 10-08-2011
mitiempo's Avatar
Caleb is right. Dowels are never used as they leave end grain exposed. Bungs are cut from a flat board and can be purchased at West Marine if you don't have the cutter to make them.
Brian
Old 10-08-2011
rugosa's Avatar
rugosa is on a distinguished road
Depending on the boat size, teak dimensions and profile, you should consider counter boring to accommodate through-bolts rather than screws. If it is midship there is considerable curve and pressure/load that will continue to work the joint. Through bolting is normally a better long term fix. Also, epoxy would be better than glue
Old 10-08-2011
Great points guys, as usual the details make the difference between professional and crap
Old 10-08-2011
jerryRiggin is on a distinguished road
Quick caveat-Careful to get epoxy that is not discolored by the sun.
Teak Rub-rail hubblect Gear & Maintenance 5 06-17-2011 10:16 PM
Repair Cracked Teak Toe Rail casey1999 Gear & Maintenance 15 02-04-2011 10:52 AM
Help removing teak toe rail saladpe Gear & Maintenance 10 11-01-2010 06:35 PM
Teak toe rail repair drlove Gear & Maintenance 1 08-26-2009 06:25 PM
teak rub rail adamlaw Gear & Maintenance 2 12-30-2007 10:32 PM
