In mast roller furling gets stuck - Page 2 - SailNet Community
post #11 of 12 Old 10-10-2011
tdw
Super Fuzzy Moderator
tdw's Avatar
Originally Posted by mgmhead View Post
When I first started using in mast furling it was a struggle and a frustration. I flushed the bearings, lubed the tracks with Sailcote, prayed to God, gnashed my teeth and cursed. Finally figured out that I had to let the mainsheet and vang run free, keep tension on the outhaul or inhaul line depending upon deployment out of or furling into the mast. And, stay slightly off the wind, in my case a little over the starboard helps to smoothly unfurl the sail and keeps the sail filled as I roll it in. Very similar to what others have described.
Keep at it and you'll find your comfort zone. That, or you might take up another activity. Golf isn't a frustrating game...
Oh no not that ... please please not that ... not golf ...
mg ... I understand your method, similar to mine basically but do you do that when reefing ? Seems to me I should be able to take in a few turns without having to let loose the main.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is online now
post #12 of 12 Old 10-10-2011
sailortjk1's Avatar
all accurate advise. pay attention to what Jakedale said, the topping lift and boom angle need to be included in the discussion as well.
Courtney is My Hero
sailortjk1 is offline
Tags
furling , in mast furl , main furling , roller furling
Behind the mast roller furling dsmylie Gear & Maintenance 16 10-31-2013 08:22 PM
In Mast roller furling NOISE FranSea General Discussion (sailing related) 4 07-16-2010 10:25 AM
Spruce Mast and Roller Furling MichaelNW Gear & Maintenance 2 10-06-2009 09:59 PM
Help! Dropping mast with roller furling? moonie5961 Gear & Maintenance 3 09-09-2009 12:41 AM
Climbing the mast ... to bix a roller furling problem... marinesniper Gear & Maintenance 16 02-02-2007 09:46 PM
