In mast roller furling gets stuck - SailNet Community
post #1 of 12 Old 10-09-2011 Thread Starter
Hi,
I sail a Beneteau Oceanis 40 with in-mast roller furling system. Problem is, the main often gets "stuck" during the furling process or the unfurling process. Not completely sure about this, but it seems that the "stuck" part happens because of the belly in the sail as it is being reefed or furled, and there is simply not enough room in the mast to handle the loose belly.
The process we undertake to unfurl is typical:
  1. Head to wind
  2. Release sheet and vang
  3. Keep tension on furl line while bringing sail out with the outhaul
Process for furling that we have been using is:
  1. Head to wind
  3. Keep tension on outhaul while bringing the sail in with the furl line.
Idea
I'm thinking that we'd be better served by hardening up on the vang, which should keep the clew "down" and the leech tighter -- thereby making the belly tighter while furling. I don't see a way that this can cause any issues, since the clew is forced to be wherever it needs to be by way of the turning block on the outhaul car. Basically:
For furling or reefing:
  1. Head to wind
  2. Release the sheet, harden up the vang
  3. Keep tension on the outhaul while bringing the sail in with the furl line
I'm equally thinking that hardening up on the boom vang (of course, keeping the main sheet loose!) while unfurling would be a good idea. The safety measure is the same -- the clew of the sail is actually not attached to the boom, but to a turning block on the outhaul car, which allows the sail to fly as high as is necessary without damage.
For unfurling:
  1. Head to wind
  3. Keep tension on the furl line while bringing the sail out with the outhaul
What am I missing? The owner thinks this is not a good idea.
Thanks for your thoughts!
marksatterfield is offline
post #2 of 12 Old 10-09-2011
jackdale's Avatar
Check your topping lift tension. There is an optimal angle for furling and unfurling the sail. You may have ease / harden the mainsheet or vang tension to get it right.
jackdale is offline
post #3 of 12 Old 10-10-2011
poopdeckpappy's Avatar
our other boat has a selden system, it works best when your not head up, keeping pressure on the sail as you furl keeps it tight.
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is online now
post #4 of 12 Old 10-10-2011
I have intentionally been eliminating boats that have an in-mast furling system from my search, maybe I will reconsider or at least try it out
peoples1234 is offline
post #5 of 12 Old 10-10-2011
Could your sail be so stretched out that it's bunching up?
Mine only gets stuck coming out at the very beginning. Usually a couple of short pulls on the in furler line tightens the roll enough that the sail has lots of clearance inside the mast, and it it then comes out easily.
At what point does it get stuck?
Ninefingers is online now
post #6 of 12 Old 10-10-2011
Battered and Bruised
Silvio's Avatar
+1 to jackdale and poopdeckpappy
In mast was not my first choice but the boat I found fit every other way. The topping lift can be friend or foe, I set mine so the boom is about 3 inches above my head which puts the aft of the boom about 5-7 degrees above horizontal. Sail furls and unfurls quite easily. Any other position and it is difficult or will bind. Also I head slightly off the wind when furling, not much but not quite in irons. I suspect that hardening your vang will cause you to fight the sail as it tries to furl. The foot of the sail should roll upward into the mast, if that makes any sense, giving an offset spiral at the bottom. At least that is how mine works on a Catalina 310.
Good luck and let us know what works for you.
SV S.S.R.I
It's my happy pill
Silvio is offline
post #7 of 12 Old 10-10-2011
tommays's Avatar
I have the Hood Stoboom and a regular roller furling Genoa
They both roll up fine BUT minor changes make big differences in the size of the roll
For example the Genoa clearly rolls tighter on a starboard reach and a somewhat loser roll will leave many wraps of line on the drum
The Stoboom is very angle dependent and only rolls up tight dead up wind
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #8 of 12 Old 10-10-2011
Old as Dirt!
svHyLyte's Avatar
The boom needs be perpendicular to the mast and a little pressure on the sail. Measure and pre-mark your topping lift and vang for the correct boom orientation (in your slip) and head off a bit to keep a little pressure on the sail when furling.
FWIW..
svHyLyte is offline
post #9 of 12 Old 10-10-2011
tdw
Super Fuzzy Moderator
tdw's Avatar
To be honest I am still trying to come to grips with our in mast furler but one thing I do know, you must keep some tension of the sail as your furl. Don't go completely dead to wind, bear away just enough to keep the sail full enough to stop the boom beating about.
(my biggest problem is controlling the outhaul as we furl .)
edit - in this case I am referring to a reefing furl not a complete furl.
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #10 of 12 Old 10-10-2011
Somewhat Senior Member
mgmhead's Avatar
When I first started using in mast furling it was a struggle and a frustration. I flushed the bearings, lubed the tracks with Sailcote, prayed to God, gnashed my teeth and cursed. Finally figured out that I had to let the mainsheet and vang run free, keep tension on the outhaul or inhaul line depending upon deployment out of or furling into the mast. And, stay slightly off the wind, in my case a little over the starboard helps to smoothly unfurl the sail and keeps the sail filled as I roll it in. Very similar to what others have described.
Keep at it and you'll find your comfort zone. That, or you might take up another activity. Golf isn't a frustrating game...
s/v Rhythm
Catalina 387 #29
Rock Hall, MD
mgmhead is offline
Tags
furling , in mast furl , main furling , roller furling
Behind the mast roller furling dsmylie Gear & Maintenance 16 10-31-2013 09:22 PM
In Mast roller furling NOISE FranSea General Discussion (sailing related) 4 07-16-2010 11:25 AM
Spruce Mast and Roller Furling MichaelNW Gear & Maintenance 2 10-06-2009 10:59 PM
Help! Dropping mast with roller furling? moonie5961 Gear & Maintenance 3 09-09-2009 01:41 AM
Climbing the mast ... to bix a roller furling problem... marinesniper Gear & Maintenance 16 02-02-2007 10:46 PM
