Old 10-10-2011
leonem's Avatar
leonem is on a distinguished road
Help-switch and warning light under companionway steps on Beneteau 390
Good morning,
Can someone help me identify the function of a switch and warning light under the companion way steps, above the engine access panel, in a Beneteau Oceanis 390?
See photo - it's the yellow warning light and the black switch on the right.
Thanks so much - much appreciated!!!
Help-switch and warning light under companionway steps on Beneteau 390-switchunderstep.jpg
Old 10-10-2011
mitiempo's Avatar
Engine room light and indicator that it is on possibly?
Brian
Old 10-10-2011
leonem's Avatar
That's a great guess - thanks - I'll check next week! (This isn't my boat) Anyone know for sure?
Old 10-10-2011
mitiempo's Avatar
Open the engine access and turn the switch on - if I am right it will be obvious.
And I think the taped over hole is for using a fire extinguisher without opening the access panel.
Brian
Old 10-10-2011
jackdale's Avatar
jackdale will become famous soon enough
Yep, I would not want to be removing that tape in case of a fire. It should have a plastic cap.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 10-10-2011
leonem's Avatar
Yeah, agreed. (Thankfully not my boat but I'll mention it to the owner.)
Will check if that switch/light is indeed the engine compartment illumination next time I'm on the boat...
Old 10-10-2011
MarkSF is on a distinguished road
You might want to put the screws back in that piece of wood supporting the top step.
The switch might also activate a solenoid valve for the LPG. Can you hear a click when the switch is toggled?
Bristol 31.1
Old 10-10-2011
leonem's Avatar
LOL yes, I'd noticed that. Lots of little issues with this boat, which, thankfully, isn't mine to worry about.
Deck light switch DanWampler Hunter 0 02-20-2011 04:56 PM
running light switch kgs113 Electrical Systems 1 06-06-2009 07:33 AM
A boat with few companionway steps dwightgry Boat Review and Purchase Forum 10 05-13-2008 10:25 AM
Alternator warning light jr438234606 Gear & Maintenance 4 02-18-2008 03:09 PM
Companionway Steps and Dogs sroth Living Aboard 4 07-23-2002 06:41 AM
