10-11-2011
1977 CS27 ~ Ravat
Originally Posted by CapnBilll
This is a sailboat right? You've got to have a metal guy wire somewhere? The higher the better. get a piece of coax. You will get the best reception with height, and an even multiple of 1/4 wave. The spacing between the wires in a coax or twin pair lead is the impedance. In an antenna you are converting from infinite impedance to usually either 75 or 50 ohms. that is what the antenna is for. The easiest way to do this, (barring the desire to to a lot of calculations), is to connect the shield to ground, and slowely move the inner conductor along the spreader, or whatever you are using until you get the best signal, permanently connect it to this point, job done.
Certainly is a sailboat, and it certainly has wire rope standing rigging. Maybe one of the shrouds is close to a 1/4 wave multiple? The catch is, I have a deck-stepped mast and I really, really, really do not want to create another deck piercing for an AM/FM antenna.
I can get good reception below decks with a cheaper portable radio using its built-in telescoping antenna, so I know that I don't need to go all the way to the spreaders to meet my needs (although it may well do a much better job up there!).
The goal here is to figure out the best options for hiding antenna somewhere within the cabin and improve upon the reception my cheapo wire is capable of.
CS27 #1254 ~ Ravat
Port of Rochester
Lake Ontario
