10-12-2011
They are pretty large.
How wide is the flange the glazing sits on? I don't see any advantage of stainless inside the recess if it is wide enough and strong enough, as it should be. Stainless on the outside to sandwich the port between it and the recessed portion of the cabin side would as you say even out the load of the fasteners but they shouldn't be so tight that there is much pressure anyway. The fasteners, with modern compounds like Dow 795, are really only there to hold everything in place until the sealant cures. It would look good but would be pretty expensive. If you did this powder coated aluminum would be another option. If they are as flat as they appear fasteners should not even be required, just a method of holding them in place until the 795 sets.
How thick is the plastic, or how thick does the plastic have to be to sit flush with the cabin side on the exterior?
I would use acrylic (Plexiglass) as it is certainly strong enough and will last many years longer than Lexan. It also will not scratch as easily and doesn't craze as easily as Lexan. They were probably acrylic originally, as are most hatches.
Brian
