Like Tree1Likes
  • 1 Post By sailingfool
Old 10-13-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
another winch question
When I crank on my mast winch the halyard bunches up on the base of the winch. The halyard goes directly from the mast head to the winch, that is mounted perpendicular and close to the mast. Is it just that the surface of the winch is too rough?
Old 10-13-2011
ASA and PSIA Instructor
The winch needs to be on a base that provides the proper entry angle, see "Line Entry Angle Important" in Harken: Winches Magnify People Power.
jackdale likes this.
Old 10-13-2011
smurphny's Avatar
Over Hill Sailing Club
smurphny is on a distinguished road
Maybe you have a halyard with a separate cover that is bunching? Some of the new Dyneema, etc. lines are covered with another more "grippy" woven tube that can bunch up.
Old 10-13-2011
Barquito's Avatar
Barquito
I think the angle to the winch is probably OK. If it is too steep, do I need to add a fairlead on the mast?
Old 10-13-2011
mitiempo's Avatar
Sounds to me like the angle is not correct. A line led to a winch parallel to the winch base will cause problems, the reason why many mast winches are angled down a bit.
From the Harken page linked to earlier:
Brian
Old 10-13-2011
klem is on a distinguished road
How many turns do you have on the winch? Too many turns for a given load will do this.
Old 10-14-2011
Barquito's Avatar
Barquito
Only 3. However, the bunching probably happens before there is much load on the line. That is probably what is happening. My last boat was 22', so I didn't have to deal with these winch-y things much.
Old 10-14-2011
Maybe you are experiencing overrides? To eliminate that risk, try starting with only two turns on the winch, add the third or fourth turns only after the line has taken a load. If you trim an unloaded line on a winch with three or more turns, you are likely to develop an override. Same situation exists with sheet winches.
Winch operation question Cruiser2B General Discussion (sailing related) 11 04-07-2011 09:20 AM
Winch question astraeus Gear & Maintenance 1 09-03-2008 08:20 PM
Dumb Winch Question jimmiebuchanan Learning to Sail 17 09-07-2007 01:59 PM
Sheet Winch Question? STLMac21 Gear & Maintenance 23 08-23-2007 08:02 PM
Winch O'haul Question simple72 Gear & Maintenance 9 12-03-2006 02:05 AM
