Old 10-14-2011
micheck is on a distinguished road
Changing fuel tank configuration...
I am contemplating changing my diesel fuel tank configuration from one small tank near the engine to two larger tanks located about 20 feet away from the engine.
1: Is remote tankage OK?
2: Should I run 2 lines from the tank farm to the engine with the selection valves located near the tanks? (less money) OR
3: Should I run 4 lines from the tanks to near the engine and do the switching there? (more convenient to monitor the action)
4: Where should the filtering equipment be located?
Charles
Old 10-14-2011
Minnewaska will become famous soon enough
Let me first say that I like the notion of redundant fuel tanks, so I would keep everything redundant, including the lines. I don't think the distance itself matters as much as the hydrodynamics of pumping fluid up hill or creating downhill pressure. I would put cutoffs at each end, for different reasons.
Jeanneau 54DS
Old 10-14-2011
blt2ski's Avatar
Some will also depend upon the fuel pump you have or may need to get. While my diesel has a pump, it is generally speaking, gravity fed! ie the bottom of the tank is higher than the top of the motor. If you are set up this way currently, you may/will need to engineer a fuel pump to get the fuel from 20' away up hill to the motor!
I've toyed with going from a 7 to a 12-15 if I can get a tank to fit in the general area of where it is now. In my case, I believe doable, question is, how big and the cost vs benefit!
marty
She drives me boat,
I drives me dinghy!
Old 10-15-2011
boatpoker's Avatar
surveyor
boatpoker is on a distinguished road
1. Adding an electric fuel pump may help and it also makes bleeding the system much faster and easier.
2. Don't forget the return lines. The fuel must be returned to the same tank it was drawn from.
Dirt People Scare me
Old 10-16-2011
PorFin's Avatar
Señor Member
PorFin is on a distinguished road
The manifold location is not critical -- it'll be a trade off with redundancy on one end and clutter/cost on the other, with convenience of access somewhere in the middle.
Adding a supplemental electric pump is a good idea, as BoatPoker mentioned.
In addition to the supply and return lines, don't forget that you also need to think about how your new vent lines will be run.
Need a new fuel tank AlLorman Pacific Seacraft 26 09-16-2011 12:08 PM
fuel tank mike dixon Gear & Maintenance 1 11-05-2009 08:35 AM
Changing Fuel Filter- How not to do it ncapener Gear & Maintenance 7 10-11-2009 07:54 AM
Yanmar 2QM15 - Changing the Fuel Filter backcreeksailor Gear & Maintenance 15 06-04-2009 07:36 PM
11.0 Fuel tank S2 Dave S2 1 08-14-2006 10:30 PM
