Old 10-15-2011
SailingWebGuy's Avatar
SailingWebGuy is on a distinguished road
C30 prop advise needed
Hello!
I have a 1976 Catalina 30 with an A4. I have almost zero thrust in reverse...docking has been a bit challenging. It currently has a tiny 2 blade prop and I don't know any specifics on it.
Has anyone had a similar issue and had good results with an upgrade? What did you upgrade to?
Any info would be a huge help. Thanks!
My complete refit is taking completely too long!
Old 10-15-2011
BELLATRIX1965's Avatar
Maine Member
BELLATRIX1965 is on a distinguished road
Recommend VARIPROP
Our boat had a fixed-pitch 2-bladed prop when we bought it, and nearly no astern thrust. Yes, docking WAS a challenge! We found later that the transmission was slipping in reverse, so check and adjust THAT first!
After much study, we purchased a Variprop feathering 3-bladed propeller.
VariProp USA - The best feathering and folding propellers in the world!
It is a robust, well-engineered German propeller, and the (very helpful) USA distributor is right in Thomaston, Maine. A wonderful piece of machinery, but EXPENSIVE! They now offer a "variprofile" prop that is similar, but quite a bit less costly. One advantage of the Variprop units is they can be adjusted for ahead and astern pitch without taking the prop apart. Adjustment can be made fairly easily by a diver with the boat in the water if necessary.
Check them out! One point if you do buy one - the custom-formed zinc "tail cones" can be purchased generically on line a lot cheaper than going back to the manufacturer. HAPPY MOTORING!
Old 10-15-2011
mitiempo's Avatar
A4 engines spin a smaller prop faster - usually no reduction gear.
Here is a link to props specifically for the A4 Boat Seem Underpowered?
Brian
Old 10-15-2011
CalebD's Avatar
Tartan 27' owner
CalebD will become famous soon enough
SWG,
Bellatrix makes a good point about the reverse gear. On our A4 we have to hold the shifter all the way back in reverse for it to begin to grab and spin in reverse. Our reverse gear is reduced so you also need to use more throttle in reverse then forward for the same prop rpms.
I have not tried the Indigo prop on our boat but I have heard good things about it. If you are not racing and don't mind a little drag this 3 blade prop is designed for use with the A4: Boat Seem Underpowered?
Hope this helps.
Old 10-15-2011
celenoglu's Avatar
celenoglu is on a distinguished road
The best prop is the one with only one blade. since it is not possible to balance it, we use the second best with two blades. Although it is easier to balance a prop as the number of blades increase, the efficiency decreases. It is up to your gear ratios not to your prop. Applying more power in reverse will help if everthing is working OK.
Old 10-15-2011
mitiempo's Avatar
The best prop is theoretically one with one continuous blade, not one blade sticking out. But it doesn't exist.
A 3 blade is both more efficient and smoother than a 2 blade.
West by North Enterprises - Choosing a Propeller
Brian
Old 10-15-2011
tommays's Avatar
I have a 12 x 8 2 blade on the Cal 29 and it is on the BIG side and i will be buying a 12 X 7 flex-o-fold over the winter
The A4 seems real happy with the 12 x 8 at 1400 to 1500 RPM and has pushed the boat with no problems in 30 knots BUT i want a bit more RPM
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 10-15-2011
SkywalkerII is on a distinguished road
Does your A 4 have a reduction drive? My C&C 34 has a 2:1 reduction so she spins a 16 inch prop. My Tartan 27 is direct drive and spins a 12 inch.
I have a 16 inch two blade feathering Maxprop if you are interested.
Good Place for OB Prop needed montenido Gear & Maintenance 1 11-06-2010 09:00 PM
Welland Canal Canada. Advise needed (perhaps legal) fparry General Discussion (sailing related) 7 06-13-2010 08:08 PM
Starter Sailboat advise needed. Have detail profile of need. osaez Boat Review and Purchase Forum 20 03-14-2010 07:55 AM
Advise needed ! dbruce85 Boat Review and Purchase Forum 5 10-21-2008 11:48 AM
Advise needed on dealing over price Mrs Mutiny Boat Review and Purchase Forum 8 02-04-2002 11:34 AM
