10-18-2011
Barquito
Ditto about raising technique. There should be some way to limit the amount of lateral movement as you raise the mast. On my C22, the aft-lower shrouds and sidestays kept the mast from moving much AFTER it was about half way up. While mast was lower, they didn't provide much lateral support. I agree with just beefing it up. If you are going to build a new one, you could also add a tang so you can attach a vang directly, or reefing line, or whatever.
