Old 10-16-2011
MedSailor's Avatar
"Fairhaven" Formosa 41
MedSailor is on a distinguished road
Best Autopilot for Offshore Work?
For the first time I'm contemplating using an autopilot instead of a windvane. Apparently autopilots have gotten much better than before and there are many reasons I don't want to totally clutter up my transom. Also with a mizzen boom overhanging the stern, I am limited in vane choice.
Can anyone point me in the direction of a few choices for offshore autopilots?
I am interested in a direct to rudder shaft connection as there is good access down there and if my steering cables give out, I'm not totally SOL. (already had that happen once)
Preferably the system would be:
Bombproof, perhaps rated for a NIMITZ class boat?
Able to steer to the wind as well as just a compass course.
Have minimal power usage.
Be easy to service and repair.
Be easy to use.
Now that I've given the impossible list, the compromi$e$ will begin....
MedSailor
"True, your boat will outperform mine to windward, but my boat will always outperform yours at anchor." --MedSailor
Old 10-17-2011
Zanshin's Avatar
Zanshin is on a distinguished road
To start off with and to eliminate unsuitable systems you should post the max gross weight of your boat. I guess that you might be in the border area between a linear electric and a hydraulic system. You can go to Raymarine Marine Electronics - Welcome and use their online autopilot selection system to get their recommended specs (then go one size up). I'm on my 3rd Raymarine now and am happy with what they do, but haven't used any other autopilots to compare against. What I have noticed is that energy consumption goes way up if the boat is not balanced well, and in very heavy weather an unbalanced boat might not be steerable with the autopilot.
Old 10-17-2011
Ilenart's Avatar
Ilenart is on a distinguished road
Sounds like a below deck system is what you are looking for. I have a Raymarine below deck with an electric linear drive hooked directly to the rudder shaft on my UFO 34. However I think a Formosa 41 would be a bit heavy for an electric unit and you are probably looking at a hydraulic unit. My last yacht (Roberts 45) had a hydraulic unit that was 25 years old and was still going strong.
All the new systems can be integrated with wind instruments so they can drive via the wind rather than just a compass course.
Ilenart
Old 10-17-2011
mitiempo's Avatar
Probably the most durable autopilot available and very capable, and in your area.
WH Autopilots
Brian
Old 10-17-2011
Zanshin's Avatar
As the OP is heading back to OZ, this limits his choices of manufacturers to the "big boys" that also have a support netowork down under. I can only think of Simrad and Raymarine but there are probably a couple of others out there.
Old 10-17-2011
MedSailor's Avatar
Ahh... Support network in my cruising area. Good thinking! Things on boats do break.....
Fairhaven is currently nimble and lighter than before, as we're not living aboard, and weighs in at 28,000lbs if you believe various spec sheets. With gear and loaded she's likely going to weigh 30-32,000# (soaking wet of course).
Medsailor
Old 10-18-2011
Ilenart's Avatar
Agree that Raymarine and Simrad are supported in Oz. I would also add Coursemaster which are an Australian manufactuer with a pretty good reputation. Not sure of availability outside of Oz. Their weblink is Welcome to Coursemaster
Ilenart
Old 10-31-2011
stiffwind's Avatar
s/v Black Prince
stiffwind is on a distinguished road
I'd like to jump into the mix here....I am likewise looking to add a under deck autopilot and have great company reviews from Garmin on their new GHP 12, for displacements from, I think 17,000 to 78,000. However I have not seen any independent input on the performance or installation...Any news or experience with the product?
s/v Black Prince
Old 11-02-2011
Pub911 is on a distinguished road
SIMRAD got my vote after comparing the heft of the drive unit to its competitors at the same boat-size rating. There are big forces at work, so installation matters at least as much as the mfg. Read up and think about the physics before you jump in, if you intend to do it yourself. My AP24 with a split 300 single drive unit has had only 1 issue since its installation 4 years ago, and that one was my fault: rainwater got to the electronically actuated clutch solenoid. SIMRAD replaced the part for free.
Albin ballad or Albin cumulus for offshore work? nightvigator Boat Buyers & Sellers Forum 11 08-31-2010 12:25 PM
Offshore performance of a Beneteau Oceanis 500 offshore JohnVerver Introduce Yourself 1 05-23-2009 12:40 PM
autopilot? bradfalk General Discussion (sailing related) 2 10-14-2008 09:41 PM
tartan 30 for offshore work? deckhanddave Boat Review and Purchase Forum 14 11-29-2006 03:00 AM
gps + autopilot bigpic Gear & Maintenance 10 05-14-2006 10:51 AM
