10-18-2011
Senior Moment Member
Originally Posted by Deric
Hello Mates,
I have an old Ronstan car that looks like the new Ronstan car#11922; however, my old must be larger because the track is wider than the tracks available by the company.
I am hoping that I can find a shop that can replace the bearings and the end caps, which hold the bearings in the car, or buy one that is used car rather than having to redo the entire car track and car.
When I needed repair on a Schaeffer block, I sent the block to Schaeffer for repair. I had hoped Ronstan would do the same. I have sent email to Ronstan and have not received a reply. I have contacted a dealer of Ronstan who told me it can't be repaired, and that I needed to buy an entire new system -- replace car track fill holes, redrill new holes, buy brand new car -- kaching, kaching, kaching.
One would think there are parts about, or left over parts sitting in a warehouse. Hard to believe that there are no bearings or plastic caps to be had.
I ask my fellow sailors for opinions and advice.
What say ye?
(picture of car and measurement of track)
The track and car are fastened to a half wishbone boom and is used for the outhaul and reefing adjustments. The boat is a Herreshoff Cat Ketch.
Thank you for your help. Deric
Find an industrial bearing supply house in your area. They can supply an incredible number of obscure bearing related items. I presume your car has ball bearings? If so or even if they are rollers or something else, there are only so many sizes they could be. Any decent bearing supplier will have them all or can get them in a number of materials. I imagine you will need Delrin balls but that's just an educated guess.
The end caps are a different story - they are almost certainly proprietary but they can usually be replaced with something else for little $$ with a bit of imagination and / or creativity. Considering the probable several $hundred cost of a replacement, I'd be tempted to investigate your repair options first.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
