Old 10-17-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Save me before I wreck my spreader
I will be storing my mast on deck this winter, so I can work on it, and to make a winter cover. The spreaders are in the way. I took one off, but the other is stuck. What can I do to break it out w/o destroying the spreader. It is actually a reasonably beefy round section tube. Chemicals, physical force, profuse swearing?
Old 10-17-2011
JedNeck's Avatar
JedNeck is on a distinguished road
How is it attached?
If it's bolted try one of the penetrating oils like WD-40 or PBblaster. If they still won't let go drill them out...you need new ones anyway.
Old 10-17-2011
BELLATRIX1965's Avatar
Maine Member
BELLATRIX1965 is on a distinguished road
I would try moderate heat, carefully applied. Heat should expand the aluminum tube, but you have to be quick - before the mount that the tube slides onto heats up and expands as well.
Old 10-18-2011
BubbleheadMd's Avatar
Chastened
BubbleheadMd will become famous soon enough
Send a message via Yahoo to BubbleheadMd
Kroil. Google it.
S/V Old Shoes
1973 Pearson 30 #255
Old 10-18-2011
RobGallagher is on a distinguished road
Originally Posted by BubbleheadMd View Post
Kroil. Google it.
Amazing stuff. Everyone should have a can on board.
Old 10-18-2011
CapnBilll is on a distinguished road
Do I read this right? Is the coroded section aluminum. Be carefull try to disolve as much as the corrosion as possible before forcing it. Aluminum galls and can make the situation worse. I have had moving aluminum parts refreeze and become permanently bonded from galling.
The Sun has Risen on a New Day filled with the Promise of Adventure.
Old 10-18-2011
Barquito's Avatar
Barquito
It is an aluminum tube inserted into a cast (aluminum I hope) fitting on the mast. The only thing that keeps the spreader in the fitting is a pin (has been removed). The other spreader just about fell out after removing the pin. This one appears to be corroded. Do I heat the fitting or the spreader?
I'll look into the Kroil.
Thanks.
Old 10-18-2011
LandLocked66c's Avatar
Sunsets and Warm Beer....
LandLocked66c is on a distinguished road
A rubber mallet and a good pipe wrench? Tap the housing and tube a little, then see if you can twist the tube inside the housing to break the bond of corrosion - Then wiggle out... That's how mine came out...
1971 23' Oday Pop Top
S/V Frida
You can't steer a boat that isn't moving? Just like a life - P. Lutus
Old 10-18-2011
hellosailor's Avatar
PBlaster or Kroil. Kroil has to be mail-ordered, PBlaster is sold in retail chains. Both chemically attack the corrosion, unlike WD40 which is just a lubricant.
Also buy a "strap wrench" at any auto partsor plumbing store. It has a rubbery strap at the business end, so it can wrap around pipes and round spreaders to grip them without chewing tooth marks into them. $10 should buy one that's good enough.
Old 10-18-2011
Yep, i'd try the strap wrench first!
S/V Frida
Did I wreck my watermaker GreatWhite Gear & Maintenance 3 04-13-2009 01:48 PM
Another wreck found poopdeckpappy General Discussion (sailing related) 13 12-18-2008 12:09 PM
SPLASH! Save the Harbor/Save the Bay Newsletter NewsReader Mass Bay Sailors 0 06-15-2006 06:15 PM
here a wreck there a wreck everywhere a wreck wreck starcresttoo Cruising & Liveaboard Forum 0 11-24-2004 11:55 AM
The Wreck of the Portland John Rousmaniere Seamanship Articles 0 10-13-2002 08:00 PM
