Old 10-21-2011
mstern's Avatar
mstern is on a distinguished road
Originally Posted by JSailer View Post
Yes, single line to the cockpit. The cable goes up through the cabin in a pipe, comes out of the cabin top and makes a 90 degree turn outboard through a block, then another 90 degree through another block toward the cockpit and ends at a cleat at the aft end of the cabin top.
What do you use to attach the line to your CB?
A knot or an eye splice?
The line has an eye splice, and then a shackle, which goes through a hole near the trailing edge of the centerboard. I bought the line/shackle from Rudy at D&R Marine.
DR Marine Product Detail
It sounds like you need a much longer line than I do though. I looked quickly on Rudy's website, and he doesn't have an Oday 30 centerboard pennant pre-made. However, I bet if you give him a call, he can tell you exactly what you need. In case you didn't know, Rudy worked for Oday for many years, and now owns the molds to some of the boats and their components. Rudy is quite the Oday guru.
  #12
Old 10-22-2011
JSailer's Avatar
JSailer is on a distinguished road
Thanks for all the info.
Very helpful.
And yes, I did talk to Rudy in the past and he is certainly a great help for O'Day owners!
O'Day 30
South Florida
  #13
Old 04-02-2012
chriswinter103 is on a distinguished road
Send a message via MSN to chriswinter103 Send a message via Skype™ to chriswinter103
Centerboard cable
I have macgregor 26 1995 with swing keel whose keel retraction cable rusted out. How, where is it attached to keel and what's the best way to replace? It comes into cabin via rubber tube and attatched to a rope going over two pullies into cleat below sink. Any tips?
You may post attachments
You may edit your posts
Centerboard cable/rope? P35juniper Pearson 2 04-26-2010 08:35 AM
Marking a centerboard cable seafrontiersman Gear & Maintenance 5 01-31-2010 08:09 AM
Centerboard Winch Cable kwaltersmi Gear & Maintenance 3 03-12-2009 11:34 AM
centerboard cable reinstall ambianceack Gear & Maintenance 8 10-11-2006 05:40 PM
Pearson 35 Centerboard Cable lazypointer Gear & Maintenance 0 12-04-2000 06:37 PM
SEO by vBSEO 3.6.1
