Gear/Rig needed for Asym. Spinn? - SailNet Community
Blogs
Old 02-20-2001
jrd22's Avatar
Courtney the Dancer
I''ve ordered a new asymetrical spinnaker(Airforce). I would appreciate any suggestions on additional equipment/rigging that will be needed. Length of sheet(s), block on deck, tack location,etc. Thanks John
Old 02-20-2001
hamiam is on a distinguished road
Not to be fresh, however, isn''t the sailmaker the correct person to ask for these questions?
Old 02-20-2001
express is on a distinguished road
Check Sailmakers Web Pages for information on rigging Asym Sails
Bill S
Old 02-20-2001
jrd22's Avatar
Courtney the Dancer
Thanks for your input. Perhaps I should have elaborated abit. I have asked the sailmaker and searched sailmakers websites for info. as well as read all the articles on Sailnet. I was hoping for some information from someone with first hand experience such as: go 10% over the recommended length for sheets, or something particular about location of tack point. Something that someone has learned from their own experience using and rigging one. John
Old 02-21-2001
I use a long tack line(guy) run throught the out board end of my spinnaker pole about 1 1/2 times boat lenght. As for sheets they are also 1 1/2 times boat lenght and I do not use shackels.I have had shackel hang up when jibing the sail. Twing lines are a great help to control leech tenison for tight reaching . For short handed stuff a sock is a good tool to have.
Bill S
Old 02-21-2001
jhowe is on a distinguished road
hi bill
i''m trying to set up a similar system. question is what purpose does the spin pole serves ( compared to a off-the-bow tack fitting )and how do u fix the position of the spin pole ? i assume u jibe with sheets outside and the pole is not telescopic.
joe.
Old 02-22-2001
I use the Spinnaker pole to get the tack of the sail forward a little bit. You can tack to the bow if you have a fitting to attach a block to.My boat is set up for spinnakers so I have all the hardware to use. The Guys from each side of the boat are run forward thur the pole end and attacted to sail tack.
This set up lets me control the fore and aft movement of the pole. The downhaul (forguy)is used to control the height of the pole. I use the pole set up for racing.For cruising I put the sail in a sock and run a tack line to bow thru Snache block to the tack of the sail. It is a lot easyer to set up.
Billn S
Old 02-22-2001
Billn S
Old 02-22-2001
Jeff_H's Avatar
Super Moderator
Some of this depends on the cut of the chute but the current theory is that the pole wants to project approximately 25% outboard than your ''J'' dimension. (Roughly the distance between your mast at the deck and your forestay.) This allows for good balance compromize between carrying the largest chute that you can that will be stabile in flight and which won''t have major interference between the mainsail and chute. As you move the tack of the sail aft toward the mainsail the chute needs to be smaller in area and will be less stabile and effective.
Most of the boats that I have sailed on with Assymetricals have sheets (on each side of the boat) that are twice the length of the boat from the tack point of the chute to the turning block at the transom. The reason being that the sheet needs to start from the tack point that can as far aft as the back of the cabin top when stetched tight for a pre-fed launch. Fron there the sheet runs around the tack point at the bow and back the length of the boat to the turning block and then forward again to the winch typically within a couple feet of the end of the cabin as well. Beyond that you need enough line to wrap the winch a few times and to have some line to hold in your hands as you start the jibe.
Beyond that twings are very important to shaping the sail and keeping it stabile. Twings act on the spinacker sheet similarly to the way that moving a genoa lead block changes genoa shape. The twings consist of a bullet block that rides on the spinsheet. The bail is tied to a control line that is lead through a bullet block at the rail and back to a cleat near the cockpit. As you swing onto a more of a reach the twin is applied to help control the head of the sail.
Now for the bad news, after years of using both types of chutes, I really think that the symmetrical chutes are much easier to fly short handed. While single-handed jibes are harder on symetrical chutes, the assymetrical chutes are a lot less stabile and take a lot more care to prevent really serious wraps, wraps of a type that you really can''t clear single-handed.
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
