10-18-2011
Senior Moment Member
Originally Posted by bljones
You're doing it in the wrong order. If you want to work wet on wet, you really don't need a pre-coat of epoxy before laying in your thickened epoxy.
Sand your corners, clean them with thinner, then lay your bead of thickened epoxy, then tool the bead into a fillet with a tongue depressor, popsicle stick, whatever. THEN lay down your fiberglass tape, and roll epoxy on to fill the weave with a corner roller, or pre-wet your tape and then fit it with your popsicle stick or tongue depressor. The when it kicks, lay on another layer of epoxy to level it out. Done.
BLJ has it right but I do one thing differently that I find makes it easier to get a good finish - DON'T try to lay the glass on top of an uncured fillet. Make your fillet as he describes and leave it to kick. When it has, wash it to remove the amine blush, scuff sand it enough to clean off any little lumps or other bits of irregularity and then put your glass tape down - I generally prefer to pre-wet the glass tape if that is what I'm using. If you are using larger pieces of fabric it's usually better to wet it in place.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
