Old 10-19-2011
regatta's Avatar
S/V Dreamer - Marieholm26
regatta is on a distinguished road
How to seal screws - deck hardware
Hello!
any advise to seale non trought bold screws? Procedure? Sealant?
Thanks in advance for any help!
Old 10-19-2011
Beersmith's Avatar
Sailing to surf
Beersmith is on a distinguished road
I am also interested in this. I understand that butyl tape is the best for bolts, but I am still confused about screws. From what I have read, polysulfide is recommended the most for screws.
My boat rebuild/sailing blog:
Please read and provide comment to my entries!
Old 10-19-2011
mitiempo's Avatar
If you are using screws to attach an item to the deck I would use the same procedure as if it is through bolted. Sealant between the item and the deck with the holes for the screws countersunk to create an O ring where it is needed most. Sealant can be Sika Flex or 3M 4200. Butyl requires good compression and works best if the item can be through bolted.
What are you using the screws for?
Brian
Old 10-19-2011
regatta's Avatar
thanks Mitiempo,
I used the butyl tape to seal trought bold like stanchion and big mooring cleats but i've a lot of stuff screwed only like small metal plates, screw for sprayhood, screw for small cleats etc etc..
I know the procedute for butyl and i did that..but i'm little confused for the other stuff.
Deck screws stripped. Kids4sail Gear & Maintenance 4 10-17-2010 04:27 PM
PSS Shaft Seal Set Screws ThirdCoastSailor Gear & Maintenance 3 09-29-2010 07:49 PM
Hull deck joint screws or bolts? labestia Gear & Maintenance 8 06-20-2010 06:23 PM
Mast/deck seal SVImpunity Gear & Maintenance 10 10-30-2009 01:33 PM
Watertight seal on thru-bolt deck hardware??? SiXeVeN Gear & Maintenance 12 09-14-2009 09:22 AM
