Replacing "bladder" in the head? - Page 2 - SailNet Community
post #11 of 12 Old 04-12-2012
Re: Replacing "bladder" in the head?
Those of you who use the Vetus bladder holding tank, do you have any problems with leaving the waste in the tank for more than a day? Vetus's web site says the tanks are for short-term (1 day) use only. We're cruisers and don't just go from pump-out to pump-out.
Julie303 is offline
post #12 of 12 Old 04-12-2012
Shortman's Avatar
Mine is a 25 gal Nauta and works fine. Certainly do not pump out every day. I installed a second vent line when I put the system in. Good venting is supposed to be the key & I have had good luck (so far!) for 7 years.
Shortman is offline
Tags
bladder , head , holding tank , vetus
Replacing wood "curtain" with wood door in head area? Catalina 27 7tiger7 Gear & Maintenance 28 05-15-2014 09:21 PM
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
Nauta fuel bladder for "holding tank"? jaschrumpf Gear & Maintenance 6 02-22-2009 06:52 PM
Head sail plastic "track" replacement zz4gta Gear & Maintenance 19 11-07-2007 01:46 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
