Old 10-19-2011
Hackettsan is on a distinguished road
Barnacles!
Another newbie question possibly.
After a complete tune-up and unfortunately close to two months at the dock with 70+ degree waters, i found we could barely move, presumablt due to barnacle build up on the prop and shaft.
I donned a mask and gloves and cleared the prop and some of the shaft and we were under way.
Once we cleared the mooring field it appeared we could barely achieve half throttle (in neutral she revved like a race car (Atomin 4 30hp)). Every time i put her in forward, she barely responded. Also vibrated tremendously in reverse.
Any chance this degree of interference can be from not having thoroughly cleaned the entire shaft (dirty bottom also)???
With only a couple of weeks left in the season and a full calendar I don't think I'll have the chance to check her out from underneath while still in the water?
Old 10-19-2011
Apologies. I see the question has been asked and answered before. I had no idea the impact these critters can have. Looks like i'm goin swimming again.
Old 10-19-2011
night0wl's Avatar
night0wl is on a distinguished road
Did you put any anti-fouling when you were hauled and put back in the water????
S/V Jendai
Beneteau 343
Old 10-19-2011
Hull was painted with ablative and the prop and shaft zinced. At least that's what the invoice said.
I just pulled four plugs that look to be a few years old, three months after a tune up, so go figure!
Old 10-19-2011
tommays's Avatar
I have to clean every two weeks with a washcloth IF I want to keep the growth light and the barnacle larva were fierce right into october
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 10-19-2011
paulk's Avatar
paulk is on a distinguished road
Do you have a folding prop? I would suspect that if you do, it is not opening fully- -possibly because of crud you missed, or which has grown and blocked the spaces that allow the prop to open and deploy as it should. We find that shifting into reverse, then forward, helps the prop to open fully if built-up crud is keeping the blades from deploying as they should. The difference in propulsion is amazing, once the blades are out all the way. If you have a fixed prop, the least amount of growth on it will detract from your performance under power. Growth on the shaft, not so much. Growth on the prop, along with things like the wrong pitch, will cause cavitation (bubbles) that result in lots of spinning and not much forward motion.
Old 10-20-2011
Yeah. Folding prop. Lot's of lessons learned for next season. Thanks again everyone.
Old 10-20-2011
jerryRiggin is on a distinguished road
Out of curiosity, where was this mooring field in which you acquired so much barnacle growth.
Tags
barnacles , power , prop , shaft
Barnacles? eherlihy Gear & Maintenance 43 09-27-2011 05:19 PM
Barnacles on gelcoat brokesailor Gear & Maintenance 6 04-21-2011 08:56 PM
Barnacles on shaft wchevron Gear & Maintenance 22 03-02-2009 06:17 PM
barnacles Loualfr Gear & Maintenance 9 10-05-2007 01:10 AM
Barnacles Alden68 Gear & Maintenance 6 05-21-2007 09:47 PM
