Toe Rail Replacement: Teak or Mahogany - Page 2 - SailNet Community
post #11 of 16 Old 10-20-2011
Tartan 27' owner
CalebD's Avatar
Originally Posted by mitiempo View Post
Caleb
The aluminum toerail you linked to is a good idea but I don't know if one is available that would work with that kind of hull/deck join. I have one but the deck sits on an inward flange of the hull, as all I have seen are designed for. Maybe there is an extrusion available that will work. It would be expensive but a wood toerail will be expensive as well as the labor involved.
Brian,
You are so right. I can't find an extrusion that will work for my hull deck joint either. I prefer the concept of the perforated toe rail over the decorative wood though.
The hull deck joint on my boat (Tartan 27) overlaps and flanges outside the hull, so it sticks out about 1-1/2".
The original poster was kind enough to post a diagram of their hull/deck joint so for a visual I give you the letter: "L". Invert it horizontally and that is my hull deck joint with an outward flange.
I've thought of swim noodles, fire hose and old tires and I'm all out of ideas.
Right now the teak toe/cap rail is looking pretty nice on our boat with just a few coats of Cetol boat snot applied to it now and again. I'd prefer the utility of the perforated aluminum toe rail but you've gotta' love the one you're with, and she looks great.
Odalisque | Tartan 27 sail #328
Everybody has one:
CalebD is online now
post #12 of 16 Old 10-20-2011
mitiempo's Avatar
Caleb
If you have an outward flange you should be able to find a non-marine extrusion that will work in aluminum - really just a properly sized U shaped channel.
Or you could do it in stainless - or bronze.
Brian
mitiempo is offline
post #13 of 16 Old 10-21-2011
neverknow's Avatar
Look for a sheet metal fab shop in your area. They might be able to make something out of either aluminum or stainless. If done from a sheet and they have a break press long enough you can get 12 foot sections made.
neverknow is offline
post #14 of 16 Old 10-28-2011 Thread Starter
After due market research in the South Florida region, I'm leaning heavily on Jatoba. It looks like teak (tight grained, absolutely gorgeous), is cheap and locally available (Shell Lumber, Miami is excellent), and most importantly it is highly rot resistant and strong as hell. My only concern is that it will be difficult to bend into shape without cracking given its great density. Anybody have any experience with this wood?
snook91901 is offline
post #15 of 16 Old 10-29-2011
72 C&C Corvette
CorvetteGuy's Avatar
I've seen boats that replaced rotten teak toerails with recycled material that has the same look as wood but with no maintnance, it bends and hold curves easily. There is a company by me and they sell outdoor furniture made of this material in many different colours from pind to black, could this be and option?
CorvetteGuy is offline
post #16 of 16 Old 10-31-2011 Thread Starter
Aesthetically, my boat needs help where it can get it, also I can't install an aluminum rail as functional as that would be, so I'm planning on wooden toerails.
Tags
toerail teak mahogany
Toe rail: Replace existing mahogany, or go with aluminum? chrisncate Gear & Maintenance 77 11-10-2013 11:07 AM
Teak Rub-rail hubblect Gear & Maintenance 5 06-17-2011 10:16 PM
Rebedding Mahogany Toe Rail & Rub Rail Finallybuyingaboat Gear & Maintenance 3 03-15-2009 09:28 AM
teak rub rail adamlaw Gear & Maintenance 2 12-30-2007 10:32 PM
