Like Tree2Likes
Old 10-21-2011
NewportNewbie's Avatar
NewportNewbie is on a distinguished road
Ripped Sail! Can this Sail be fixed?????
Just noticed a rip in my sail....@%^&#!!!!! Anyway...can it be fixed or should I look into replacing it?
S/V Cuajota - 1975 WD Schock Santana 30
Old 10-21-2011
Repairable but the sail looks kinda 'done'.. and may not be worth putting more money into it... Just get some sail repair tape (self adhesive) and fix it for now until you're ready to replace it.
Like this: http://www.boaterbits.ca/sailboat-ha...ging/tape.html
jackdale likes this.
1984 Fast/Nicholson 345
Old 10-21-2011
Peas's Avatar
Peas is on a distinguished road
I agree with Faster - the sail does kinda looks 'done'.
Maybe check out one of the online used sail lofts for something that might fit, if you don't want to spend thousands on new.
Depending on how bad the tear is on the leach, if it's a patch on the panel that's required - maybe $100 at your local loft would take care of it?
Old 10-21-2011
jackdale's Avatar
jackdale will become famous soon enough
Since the tear is below the spreader patch and not along a seam, I agree that the sail may be done. The loft should be able to give you an assessment and an estimate.
Is this sail on a roller furler? If it is, it should have an anti UV strip, which I do not see.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 10-21-2011
emoney's Avatar
emoney is on a distinguished road
Is that your only jib? Sail tape is readily available at almost all chandleries. West Marine carries it. But, if it's your main working jib, and that's what is most often used, time to start shopping for a new(er) one. I'm sure there's plenty sail lofts there in Newport. I've had good luck in purchasing trade-in sails in the past, if you need to save money.
Old 10-21-2011
yes its son a furler. Its the way I got it....I took it to North Sails when the leach line ripped. They repaired it and said the sail was good for a few more seasons. That was a few months ago.
Old 10-21-2011
jackdale's Avatar
I would guess that the torn leech is also the result of UV. A UV strip is essential and can be retrofitted.
Old 10-21-2011
emoney's Avatar
You know, as an afterthought, if there's even a slim chance you're thinking of "trading up", then I'm of the opinion you'd be much better served to replaced that sail. Prospective buyers, especially those that are new to sailing, can get "turned off" a potential purchase by the fear of sail replacement. I'm sure you'll get back the cost in resale value, in that you should be able to purchase, if nothing else, a used sail for quite a bit less than a future buyer will deduct from his/her offer factoring in replacement.
Old 10-21-2011
pdqaltair's Avatar
pdqaltair is on a distinguished road
An excellet chance to learn sail repair.
Get a strip of cloth from the local sailmaker, a sewing palm, sailmakers needles, waxed thread, a book from the library, and learn. Someday you will need to repair something in a bind, and this is a great chance to learn with no consequences. It's actually kind of fun. And done well, the repair may last years, certainly longer than the rest of the sail.
I wouldn't pay someone to fix it. The sail is long in the tooth. You'll replace it someday. I wouldn't argue against that. That sort of tear suggests weak cloth.
(when asked how he reached the starting holds on a difficult rock climbing problem that clearly favored taller climbers - he was perhaps 5'5")
"Well, I just climb up to them."
by Joe Brown, English rock climber
Old 10-21-2011
WDS123 is on a distinguished road
Newport,
a few choices ranging from very home spun to professional:
1) duct tape (get white)
2) Spinnaker tape
3) Patch using old fashioned sewing method
4) Minny's - buy old but servicable genoa for a couple hundred
5) WD Schock - buy a brand new Genoa from us.
Ripped Sail along Seam Question CraigCS27 General Discussion (sailing related) 3 08-30-2011 09:07 AM
Ripped Main Sail Flybyknight Gear & Maintenance 2 06-18-2010 08:25 PM
Ripped my main sail SSBN506 Gear & Maintenance 15 08-27-2008 09:19 AM
Melbourne Club Marine Sail Boat Show - Sail World NewsReader News Feeds 0 03-18-2007 06:15 PM
Sydney Yachts at Strictly Sail Pacific @ Sail World Australia NewsReader News Feeds 0 04-17-2006 08:15 PM
