Contemplating a drive line overhaul - Page 5 - SailNet Community
 8Likes
post #41 of 48 Old 11-04-2011 Thread Starter
Learning the HARD way...
eherlihy's Avatar
Originally Posted by deniseO30 View Post
How's bout a slide hammer like they use on body work?
Thanks D- but I can not see how that would help.
I need to press the shaft forward (which I can do with the hammer - which I will stop) or press the coupling aft. There is NO ROOM between the transmission and the nice-new-shiny PSS Shaft seal to fit a hammer, even a slide hammer, to push the coupling aft.
eherlihy is online now
post #42 of 48 Old 11-04-2011
JimsCAL's Avatar
Some comments.
1. The ring in your rudder picture is not the rudder bearing, its just a spacer. The lower rudder bearing is up in the bottom end of the rudder tube.
2. With all that water in the rudder, I would be concerned about delamination in the rudder and possible corrosion of the internal structural grid. I would check this out before putting it back.
3. I agree to stop hammering. Sounds like the fit between the coupling and shaft is too tight. Take it apart (if you can) and take the shaft and coupling back to the propeller shop and have then fix things.
JimsCAL is online now
The Following User Says Thank You to JimsCAL For This Useful Post:
abudoggie (07-05-2014)
post #43 of 48 Old 11-04-2011
Maine Sail's Avatar
Eherlihy,
Here's what I suspect;
1- That coupling has already been on and off the shaft a few times when they fitted it and faced it. It did go on/off without "heavy" hammering so that means something has happened between then & now.
2- It is possible you dropped the shaft on the coupling end and caused a burr that was enough to cause issues.
3- You possibly did not start the shaft into the coupling STRAIGHT and created a ridge & pushed it or created a burr. Even a few ten thou will cause any sort of defect in the coupling or shaft to bind up as this is an interference press fit.
4- REMOVE the coupling by pressing it off with a socket and some bolts. Check the outside of the shaft and inside of the coupling for any defects.
5- The Tef-Gel may have helped cause this issue as it "lubed" the shaft and allowed the burr or defect created by starting crooked to worsen until it completely bound up.
6- It is CRITICAL that the coupling be started 100% straight. Bolting the coupling to the gear box can help get it started and with a LIGHT tapping with a wood mallet, lead hammer or brass hammer you can get it to start easily. Once it is started straight it should simply "tap" into place. Use TWO people...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #44 of 48 Old 11-08-2011 Thread Starter
eherlihy's Avatar
Just letting you know that I am away from the boat for two weeks... I will post again when I can get back, and remove the coupling.
post #45 of 48 Old 11-20-2011 Thread Starter
eherlihy's Avatar
The solution was about 7 min with this:
I used a 19mm socket to press the coupling off the shaft, as has been written about elsewhere. Once it was off I examined it for any scratches, burrs, or other defects. There were none to be found.
I then heated the coupling to about 150 with the heat gun, and tried to re-install it. I was shocked when it SLID on by hand!
I also noticed that the starboard rear motor mount is way out of adjustment. I will probably replace them all and be done with it.
post #46 of 48 Old 05-07-2012 Thread Starter
eherlihy's Avatar
Re: Contemplating a drive line overhaul
Before;
After;
Note that the batteries are not yet re-installed for the season.
New motor mounts;
BarryL likes this.
post #47 of 48 Old 05-07-2012
BarryL's Avatar
Nice!
Looks great and well done.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is online now
post #48 of 48 Old 05-07-2012 Thread Starter
eherlihy's Avatar
Thank you Barry.
I spend the time to photograph and document this stuff to give other O'day 34/35 owners (other brand / model boat owners too!) some ideas, and the courage, to try and tackle some this stuff themselves. If I can do it, anyone can.
Here is what the engine looked like when I bought her in the fall of 2010;
The cooling hose is held clear of that old Motorola 50A alternator by Zip Ties!
The old style M25 alternator bracket! Which explains the new timing case cover.
The coolant pump leaked like a sieve. (See that green fuzzy stuff - coolant!)
That T on the coolant elbow was full of air, so the temp never read accurately.
The wiring was a rats nest, everything was re-wired, but not to ABYC color code, nor was it documented.
the seal around the crankshaft was cracked and leaked. It sprayed a light coating motor oil over everything.
I had 2 surveyors look at the boat and neither one thought anything was amiss...
Hot water heater was plumbed into the main cooling circuit, with big honkin' hoses.
Wooden backing plate NPT/NPS fittings and a strainer on the undersized through hull. I couldn't reach that through hull handle either.
Sorry to see that your stem head fitting cracked. Let us know how you get it repaired.
Rudder Overhaul ranes Gear & Maintenance 52 12-19-2015 12:12 AM
Keel saga, for those contemplating this procedure for your boat... CharlieCobra Gear & Maintenance 44 11-20-2011 02:12 PM
Contemplating new sails PalmettoSailor Gear & Maintenance 29 11-10-2011 04:00 AM
DIY diesel overhaul jeffb General Discussion (sailing related) 2 12-09-2005 05:03 PM
Contemplating Hurricane Season SailNet Seamanship Articles 0 05-19-2001 08:00 PM
