Chain plate metal bad - Page 2 - SailNet Community
post #11 of 12 Old 10-26-2011
Our 1989 Cabo Rico 34 lost it's mast due to..what the original owner described as sub par stainless that was used in it's construction as per a metal analysis in order to have Cabo Rico replace all new standing rigging and mast...
aa3jy is offline
post #12 of 12 Old 10-26-2011
Break, curse, fix, repeat
bwindrope's Avatar
Yes, mitiempo, I thought 1/8 was thin too. Given that a Gulf 32 displaces about 16,000 lbs, and has 6,000 lbs of lead in the keel, it takes a hell of a lot of force to get her to heel over. Her rig is not too tall, but I have never ever been able to get her rail in the water even carrying full sails close hauled in winds to 25 knots. The forces on those chainplates, and the rigging, must be pretty large, and larger because of her mass.
For all these reasons and more I felt good about replacing them and increasing the thickness of the chainplates.
I hadn't thought about using the old ones as backing blocks but I like that idea. Gulf 32 chainplates are bolted to the large teak bulkheads that separate the main cabin from the head and vberth. They have teak backing blocks for the chainplates. When I install these new ones I will see if cutting down these old chainplates might work to replace or supplement the teak backing blocks. I like that idea.
Aeolus
Gulf 32
Bainbridge Island, WA
bwindrope is offline
chain plate reinforcement UseDaGreyMatter MacGregor 1 12-31-2010 12:05 AM
Chain plate help atlanticcruiser Gear & Maintenance 15 12-20-2010 01:46 PM
Chain Plate (Not) davidpm Gear & Maintenance 2 04-14-2009 07:52 AM
Chain plate leaks Handidude Gear & Maintenance 4 10-20-2008 06:46 AM
Metal Plate gg30citation Gear & Maintenance 4 11-03-2007 12:31 AM
