10-26-2011
Lies about her age
Right angle grinders? Those are for removing lots of material in short order. Like welds. Most stone type wheels clog real quick because of the high rpms when used on wood, or glass. Sanders come in the same right angle type but with lower rpms. (also used for polishing) Suggest 7 - 9" dia
Large surfaces like a deck or hull will become wavy from using right angle grinders also. (the larger the disk the flatter it can lay on the surface) Random orbit sanders (a great invention!) take less from a large area while keeping the disk flat, but take hours and hours to remove large amounts of material In all cases the sandpaper needs to be changed often since gelcoat and substrate are much harder then wood.
"Fairing" Is the making or prepping of a surface fair smooth like a table top, or fair like the curves of a boat, airplane, or car. (no ripples or dibits) is easier to maintain the fairness of a surface then fix the damage done from heavy grinding of a surface. You might take a trip to an auto body shop and watch how they work to keep the surface "fair" on cars being repaired.
