Cetol...off! - Page 2 - SailNet Community
post #11 of 19 Old 09-18-2003
Cetol...off!
Warning some chemical strippers eat fiberglass
KenD is offline
post #12 of 19 Old 12-27-2010
I have removed all the cetol from my Hans Christian quite a few times over the years. A heat gun and a scraper (for flat surfaces), green scrubby pad for curved surfaces, is sufficient. Be careful not to burn the wood with the heat gun. I then clean the teak with Snappy 2 part cleaner (NEVER use a brush - just a green scrubby pad). Wear heavy neoprene gloves, and use LOTS of water on the teak and all adjacent surfaces. The teak will sand (if you need to) easily with 320.
WIth this method you will not damage the wood or unnecessarily wear it away by sanding the cetol off.
Then apply 2 coats of cetol teak. If you are not going to step on the surface then you can put 2 coats of cetol clear and you will get a great near-to- varnish finish.
I do not recommend cetol for decks. Just clean in the fashion I outlined above and use a good teak oil, like Tip Top Teak.
4enginesailor is offline
post #13 of 19 Old 12-27-2010
Welcome to the forum 4engine... Being your first post, you probably didn't notice that this thread hasn't been posted to in over 7 years. Most prefer to engage in fairly current discussions or just start their own new one.
Cetol removal is an age old problem. It seems more people want it off than on. I prefer off.
Minnewaska is offline
post #14 of 19 Old 12-27-2010
Tartan 27' owner
CalebD's Avatar
I'm a bit surprised it took to the 12th post in this old thread that somebody mentioned a heat gun. Heat gun and scrapers, lots of them. Works like a charm.
Welcome 4enginesailor.
Everybody has one:
CalebD is offline
post #15 of 19 Old 12-28-2010
Old as Dirt!
svHyLyte's Avatar
Caleb--That may be because heat does not do particularly well on Cetol, but can make an unnecessary mess. A couple of good sharp cabinet scrapers will make short work of Cetol and a keeping a shop-vac close at hand during the process can pretty much eliminate mess.
On Cetol colors, our dock neighbors recently redid their birghtwork with Cetol Natural Teak finish and 3 coats of gloss with excellant results. We will move from Cetol Light to the Natural Teak finish during our spring re-fit.
FWIW...
svHyLyte is offline
post #16 of 19 Old 12-28-2010
Tartan 27' owner
CalebD's Avatar
Cetol Natural Teak does look very nice.
I've used the heat gun on our teak toe rails that were previously varnished. This might explain why I was under the impression a heat gun would work.
Everybody has one:
CalebD is offline
post #17 of 19 Old 12-29-2010
Old as Dirt!
svHyLyte's Avatar
Caleb--
Varnish seems to be much softer than Cetol and does give itself up to heat pretty readily. Cetol not so much although some do try to use heat. It is the relative hardness of Cetol that seems to make it more seseptable to scraping. I recently did a 10' long 3.5" wide teak grab-rail in about 15 minutes with a good quality scraper that pulled the Cetol and did very little damage to the underlying wood, which needed only a few minutes with 220 sandpaper. Frankly, the only thing I've come across that seems to damage Cetol is bird poop. Here in southwest Florida we seem to have a lot of Ospreys of late and their waste is very damaging--hence the need to redo our grab-rails.
Others may (certainly will) disagree with the foregoing but that has been my and a couple of my dock-mates experience. (A couple of us get together and share the cost of a quart of Cetol Gloss each Spring, and colored Cetol when necessary.)
FWIW...
svHyLyte is offline
post #18 of 19 Old 12-29-2010
I've had good luck removing a 10 year build up of the original color cetol with a heat gun and scrapper. The cetol natural was put back on and have been happy with the look. It was not clear to me if the gloss finish was necessary to add, but I found that adding the gloss helps with the UV protection. Wish cetol would make that clearer in their instructions.
lancelot9898 is offline
post #19 of 19 Old 12-29-2010
poopdeckpappy's Avatar
Just to throw out another option, try a gel stripper ( either citrus or soy ) they work really well and they won't hurt the gelcoat, plus the scrappings stay moist enough that they won't blow around letting you have both hands free to work. After you've worked a area with good cabinet scrapers, you can go back with a shop vac and clean that area.
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Lord, give me coffee to change the things I can change and Rum to accept the things I can't
poopdeckpappy is offline
Cetol jccrane Gear & Maintenance 5 03-31-2004 04:43 PM
sikkens cetol question gwp Gear & Maintenance 4 12-21-2003 05:02 PM
Haze on new cetol ??? skyamsen Gear & Maintenance 2 10-20-2003 07:53 PM
Cetol vs cetol light Lastmango69 Gear & Maintenance 2 07-22-2003 05:12 PM
Cetol removal? WillS Gear & Maintenance 2 05-17-2002 10:57 AM
