Old 10-26-2011
NewportNewbie's Avatar
NewportNewbie is on a distinguished road
Changing Traveler leads....cant be that hard right?
This is probably a newb question...I need to change my traveler leads. I though just unscrew the 3 screws, the plate will pop off, take the old leads out, drop the new ones in and screw the top plate back on. Well Doesn't seem that simple. One screw has the bolt just over the track. Once its loose, not enough room to get under there and tighten it. So I thought, ah..the other 2 must be to remove the end from the track. Got one screw loose, but the other one won't budge. So I thought I'd ask here before doing any damage....Here is a pic of where the leads attach to the traveler.
S/V Cuajota - 1975 WD Schock Santana 30
Old 10-26-2011
What exactly are you wanting to change? The line? the pulley? the cam cleat? or just move the location?
1984 Fast/Nicholson 345
Old 10-26-2011
deniseO30's Avatar
Lies about her age
If they won't come out, rather then break them, just cut the line and use Bowline knot to tie the new on.. won't be pretty as a loop, but it will work. Looks awful light duty for a 30ft boat imho,
gotta love Garhaurer,
yes, I know the color is on the wrong side LOL
Old 10-26-2011
Trying to change the lines. I had some new lines made with a loop so id LIKE to have that.
Old 10-26-2011
..and I suppose that's the bolt that won't budge... looks like SS in aluminum, could be fun. You could try an impact driver after soaking with some PB Blaster.
Otherwise you may have to do as Denise suggested.. or end-for-end the line while it's new and do your own splice on the pin after cutting the old line out.
Old 10-26-2011
paulk's Avatar
paulk is on a distinguished road
Each of the three machine screws seems to be different, so at least two of them have probably been replaced by the Previous Owner. He likely neglected to bed them so they wouldn't slowly corrode into permanent lumps in the aluminum. Good luck. Patience and a lot of penetrating oil may help.
Old 10-27-2011
rugosa's Avatar
rugosa is on a distinguished road
Maintenance, maintenance, maintenance - every owner should develop regularly scheduled maintenance for EVERYTHING on their boat, especially in salt water locations. Weekly, monthly, quarterly, half yearly, annual. It's easier to do with a new boat when you don't need to be concerned about previous owner neglect. Unfortunately with older boats it is all too often a game of catch up.
Pics look like someone has replaced Garhaurer cam with Harken. Tie or splice new line on for now to get going, plan system removal and overhaul over the winter, or a new traveller system in the future.
Sheet Leads with Yankee on PSC 37 BirdBrain333 Pacific Seacraft 2 01-12-2011 07:47 PM
Changing traveler location? downeast450 Gear & Maintenance 9 09-04-2009 10:07 AM
At sea. Volvo Ocean Race: Hard nights work changing headsails for Ericsson Racing Team @ BYM Sailing News NewsReader News Feeds 0 04-16-2006 04:16 AM
Adjustable Sheet Leads Brian Hancock Seamanship Articles 0 02-08-2002 07:00 PM
Insurance leads . . . VIEXILE Cruising & Liveaboard Forum 1 01-14-2002 04:23 AM
