10-28-2011
Originally Posted by MarkSF
A couple of years ago the previous owner had the whole bottom done with black Trinidad SR. They just added a couple of coats to what was there already.
The problem now seems to be that the top black paint layer is flaking off in places, and has the odd bubble in it. Not to be confused with true blisters, it's water getting under the badly-adhered top layer.
I can only assume that the bottom wasn't properly prepared before painting.
Soda blasting 20 layers of paint off seems a bit drastic. Is there a process, apart from sanding which isn't allowed, which can just remove the top layer and get down to sound paint? Can they soda blast lightly?
The current issue of Practical Sailor has an artical on soda blasting vs other methods. From what I understand soada blasting is pretty gentle on the gel coat, more so than sanding. The article indicated that soda blasting in general is quicker than sanding although I just got an estimate from my yard in Maine to have 30' botom stripped, sanded, barrier coated and painted that was better than expected from reading the article.
