Old 10-29-2011
montenido's Avatar
montenido is on a distinguished road
Thickened Epoxy Question
Hi all,
I am fabricating two small spacers for a stern roller installation to gain some height. Each spacer will be about 1x2" square and maybe 1" thick. I have made two so far using polyester resin with layers of fiberglas mat and fabric.
I would like to build these using epoxy, and then epoxy them to my transom. Can I make these using only epoxy with the high-density filler? Or should I once again layer glass cloth and matting?
I have "potted" plenty of holes with the thickened epoxy, so I know it is strong.
Comments? Opinions?
I have attached a pic of the roller sitting on my fiberglass spacers, and the mold is in the picture for reference.
Thanks, Bill
Odyssey, '79 CSY 44 Cutter
Channel Islands, CA
"There is no unhappiness like the misery of sighting land (and work) again after a cheerful, careless voyage."
Mark Twain
Old 10-29-2011
Part of the solution
bljones has a spectacular aura about bljones has a spectacular aura about
a couple of layers of 'glass oriented at right angles to each other would give you a little more structure. make a thickened epoxy sandwich in your mold:
1.layer of thickened epoxy
2.saturated cloth on nw-se diagonal
3.saturated cloth on ne-sw diagonal
4.layer of thickened epoxy
It's 5 o'clock somewhere:
Old 10-29-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
The easiest method to add some fiber strength is to thicken the epoxy with "mill fibers" - short bits of glass fiber. I doubt that, in a piece that small, woven fabric would add enough to be worth the trouble.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Old 10-29-2011
garyguss is on a distinguished road
Man, that looks like a lot of work, I think I would have cut some spacers out of a Walmart plastic cutting board and gone on to the next thing. Could make a couple of little molds and cast them out of epoxy with milled fibers. As long as they dont get too thick and overheat.
Old 10-29-2011
Frogwatch is on a distinguished road
Use G10 (Garolite)instead. Order it from McMaster _Carr online. It is extremely strong and bonds well to epoxy. I use it for similar stuff when I build boats.
Old 10-30-2011
mitiempo's Avatar
Thickened epoxy with glass fibers added should be ok. Why do you want to raise it though? The higher it is the more bending force on the bolts holding it.
I have the same stern roller and will be installing it in the future - direct to the stern deck.
Brian
filling 4" deck hole - epoxy/fiberglass question stantale Gear & Maintenance 10 07-29-2011 01:56 PM
Thickened epoxy really necessary? L124C Gear & Maintenance 16 10-24-2010 04:01 PM
epoxy primer question JESTER458 Gear & Maintenance 1 06-01-2010 02:28 PM
epoxy to fiberglass question? CapnRon47 Gear & Maintenance 3 06-10-2009 01:06 PM
QUestion about epoxy. What is "kicking"? duffer1960 Gear & Maintenance 3 05-02-2005 12:28 PM
