slipping winches - Page 2 - SailNet Community
 8Likes
post #11 of 39 Old 11-01-2011 Thread Starter
"Sparkie"
j34035's Avatar
They do work better with larger lines. There are springs on the grippers, maybe they have gotten a bit weak over the years? I will check with a couple of local machine shops so see what they can can recommend. I am not sure about putting the non-skid on the drum, it may grip too much. Thanks for the feedback from all.
DD
Doug
Jboat J/37c (new to me Jan 2011); J/22 #1003
j34035 is offline
post #12 of 39 Old 11-01-2011
try winching without using the self tailers if they grip ok the its in the self tailer if they dont it is the drum is too smooth
Ninefingers and PaulfromNWOnt like this.
cruisingdream is offline
post #13 of 39 Old 11-07-2011
If you decide the drum is too smooth, a few minutes on a lathe with a knurling tool would fix it.
Capt Len is offline
post #14 of 39 Old 11-07-2011
Self tailers are designed to work with lines within a specific range of sizes. It might be that you are using lines that are smaller than your winches were designed to use.
jackdale likes this.
Sailormon6 is offline
post #15 of 39 Old 11-07-2011 Thread Starter
"Sparkie"
j34035's Avatar
I have used lines on these winches ranging from 5/16" (too small I know) to 1/2". The larger ones grip better, but still slip. The 3/8" and 7/16" slip quite a bit. Using the above logic, the drums are too smooth, but I am not sure about knurling them, though that is a pretty good thought. How will the chrome survive? Maybe have to re-chrome them? I have a full machine shop available to me and we have knurling tools that will do the trick. Gonna have to do some thinking on this one. Re chroming 6 winches will be pretty expensive; I could sell them and buy lewmars or harkens to replace them. Thanks for all the feedback.
DD
Doug
j34035 is offline
post #16 of 39 Old 11-07-2011
I naturally thought you'd buff off the chrome first. Why would you want chrome when you can have bronze?
SloopJonB likes this.
Capt Len is offline
post #17 of 39 Old 11-08-2011
Senior Moment Member
SloopJonB's Avatar
DD
If you go that route, go very easy on the knurling - you don't want them getting a surface like the handle of a breaker bar or you'll really wear out your lines quickly.
Have you had another experienced sailor check them out? They might be able to spot something you missed. A winch shouldn't require anything close to a knurled surface to grip properly.
SloopJonB is offline
post #18 of 39 Old 11-08-2011
Send a message via Yahoo to dacap06
I think the others have nailed the issue -- smooth drums, weak tailer springs, worn tailer gripping surfaces, or some combination of the above. In two of those three conditions you will need to purchase new parts.
Barient went out of business years ago, but parts are available from Hutton-Arco in Australia, also known as the Australian Winch Company. I have Barients too, and when I needed bearings they were the only source of parts I could find. Take a look at their web page: HUTTON-ARCO Yacht Winches
Good luck!
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #19 of 39 Old 12-14-2011 Thread Starter
"Sparkie"
j34035's Avatar
I believe we are down to smooth drums. I did call Allen Hutton with Hutton Arco and they can rework 2 winches for $300. I will probably do that if I can figure out the shipping within reason. Any ideas? Thanks for all the feedback from you guys!
DD
Doug
j34035 is offline
post #20 of 39 Old 12-15-2011
SloopJonB's Avatar
I believe we are down to smooth drums. I did call Allen Hutton with Hutton Arco and they can rework 2 winches for $300. I will probably do that if I can figure out the shipping within reason. Any ideas? Thanks for all the feedback from you guys! DD
I'd talk to some local people first - machine shops, mast builders - like that. Shipping even the drums to Oz is going to co$t. Shipping is usually charged by both weight & volume and you'll have the weight.
You don't need much texture on the drums - well less than normal knurling. Perhaps a machine shop can suggest another method of lightly texturing them.
Safe grounding, without slipping BudgieSmugglers Cruising & Liveaboard Forum 4 01-11-2011 07:55 PM
slipping winch xort Gear & Maintenance 13 08-08-2008 05:04 AM
High RPM = slipping out of forward??? olysailor Atomic 4 10 06-21-2008 10:24 AM
Slipping at Anchor nauticalrich General Discussion (sailing related) 22 05-18-2006 02:14 PM
Hurth HBW-5 tranny slipping??? Philschophoto@comcast.net Ericson 0 05-17-2006 05:37 PM
