Like Tree8Likes
Old 10-30-2011
j34035's Avatar
"Sparkie"
j34035 is on a distinguished road
slipping winches
I have chrome bronze Barient self tailing winches on my J/37 and under a load, they slip when I am grinding. Any ideas on how to gain traction on the drums?
DD
Doug
Jboat J/37c (new to me Jan 2011)
Old 10-30-2011
PaulfromNWOnt's Avatar
PaulfromNWOnt is on a distinguished road
How many turns do you have on them when you're grinding? My first thought is to add one more.
HTH
Old 10-31-2011
mm2187 is on a distinguished road
Is the "line surface" unusually smooth. try putting another line you have on them...Your halyard/sheets might be old. Try a different line.
Schock - New York 36
Portsmouth, RI
Old 10-31-2011
j34035's Avatar
"Sparkie"
I have tried all that, as many wraps as I can get and changing to different lines. BTW, the VPC is the worst of the bunch as far as slipping and plain old double braid dacron is the best. Larger is better also, but I dont want to be using large line just to keep the winches from slipping.
DD
Doug
Old 11-01-2011
Then likely your drums are smooth to the point where they won't grip the line. Sadly, I don't know the remedy other than replacement.
Old 11-01-2011
HUGOSALT is on a distinguished road
Doug, Although unorthodox try purchasing non skid material
that one might stick on a compaignway ladder...cut it to fit around
the drums and see if you don't get some trackion.
Good luck, Hugo
Old 11-01-2011
puddinlegs is on a distinguished road
There are machine shops that will texture the drums for you... no need to throw good winches out.
PaulfromNWOnt and SloopJonB like this.
Old 11-01-2011
paulk's Avatar
paulk is on a distinguished road
Puddinlegs has the right idea - the winches could be rescored. You could try to achieve the same result with nonskid material (as suggested) or nonskid paint, but that might look really hokey and might actually grip the line too well. (You want the wraps to come off when you tack, and pretty quick, too!). Attacking the drums with a sharp file or a drill-mounted wire wheel might also work. If you're patient and have a steady hand, that might be a less expensive option, and wouldn't require demounting the drums.
Another possible issue could be that the jaws on the self-tailing mechanism need to be adjusted. If you've been using different sized lines, the jaw spacing could have been affected. (I was going to suggest getting someone stronger to do the tailing...)
Old 11-01-2011
jackdale's Avatar
jackdale will become famous soon enough
In what condition is the gripper on your self-tailing winches? The fact that larger lines work better might be a hint.
Faster likes this.
ISPA Yachtmaster Offshore Instructor Evaluator
CYA Advanced Cruising Instructor
Old 11-01-2011
I'm with Jack... if they are self tailers then it would seem the problem would be there.
1984 Fast/Nicholson 345
Safe grounding, without slipping BudgieSmugglers Cruising & Liveaboard Forum 4 01-11-2011 06:55 PM
slipping winch xort Gear & Maintenance 13 08-08-2008 04:04 AM
High RPM = slipping out of forward??? olysailor Atomic 4 10 06-21-2008 09:24 AM
Slipping at Anchor nauticalrich General Discussion (sailing related) 22 05-18-2006 01:14 PM
Hurth HBW-5 tranny slipping??? Philschophoto@comcast.net Ericson 0 05-17-2006 04:37 PM
