Upgrade prop to a feathering prop - Page 2 - SailNet Community
 1Likes
post #11 of 48 Old 11-04-2011
Got it, fallard... thanks. I was wondering if you'd had an issue with the prop itself when towing and couldn't quite envision what it might be...
I do think, though, that that might depend on the dinghy package that you tow, and how you tow it, as to how insignificant the 'improvement' might be...
Faster is online now
post #12 of 48 Old 11-04-2011
Maine Member
BELLATRIX1965's Avatar
Generally agree with what has been posted previously - I would consider carefully before buying a folding prop - I don't have first hand experience, but have heard lots of horror stories.
After much comparison, we bought a Variprop 3-blade. Very robust hub assembly, excellent thrust ahead (especially considering the relative flat blade profile), seemingly reduced drag under sail, but no specific data on our boat to prove that. Much better astern thrust than the previous 2-blade fixed prop. Unique "clutch" function in the hub prevents the "bang" that happens when some other feathering props hit the stop at full pitch. Variprop is German made, USA distributor in Thomaston, Maine. Ahead and astern pitch can be easily adjusted - even underwater.
At the time we got our Variprop (about 4 years ago), the Maxprop could not be adjusted for pitch without disassembling the hub - maybe that has changed.
It was expensive, but worth it in my opinion - very well engineered and manufactured piece of machinery. Variprop now has a new line of less-expensive props - the Variprofile. I have no experience with those.
BELLATRIX1965 is offline
post #13 of 48 Old 11-04-2011
I don't believe it has... still requires re-aligning the internal bits... an experienced diver may be able to do this afloat but it would certainly be more straightforward on a hoist.
post #14 of 48 Old 11-05-2011
I don't discuss my member
Fstbttms's Avatar
Max Prop has had a variable pitch model model for years. Can be easily adjusted underwater without disassembly. That being said, an experienced diver can repitch any Max Prop model underwater. Frequently cheaper than a haulout and certainly more convenient and less time consuming for the boat owner. PYI can recommend a diver near you.
Fstbttms is offline
post #15 of 48 Old 11-05-2011
Senior Moment Member
SloopJonB's Avatar
Does anybody here have direct experience of changing between fixed, folding and variable / feathering props on the same boat? I'm particularly interested in hearing from anyone who has instrumented documentation of exactly how much difference the folders etc. improve sailing performance over a fixed prop.
This subject is a bit like anchors - "everybody" knows that fixed props "kill" sailing speed, but it's all seat of the pants opinion as far as I've been able to determine. I've never seen any sort of documented info on speed differences between different types of props on the same boat.
The reason I ask is that I have learned that there is a wide variation in what sailors regard as significant. In a conversation with the previous owner of my old race boat, he spoke of a change he had done that made a "Huge difference, Huge" - I later discovered it was 1/10th of a second a mile. I guess it mattered at the Worlds but it sure wasn't something I'd spend money on.
Is that the sort of thing we are speaking of here or is it more like a knot on a 33 footer?
SloopJonB is offline
post #16 of 48 Old 11-05-2011 Thread Starter
patrscoe's Avatar
Thanks for all the advice and information.
I have learning towards a feathering prop so I think I will stay in that direction.
I will price up both, Max prop and Variprop.
It's good to get some user input as any product literature, everything sounds great until you use it and realize that it is not exactly what you thought.
Thanks
Patrick
S2 11.0A 36'
Kinsale, Va
Tanzer 16'
Moseley, Va
patrscoe is offline
post #17 of 48 Old 11-05-2011
Does anybody here have direct experience of changing between fixed, folding and variable / feathering props on the same boat? .......
On our 40 footer we went from a 2 blade Martec folder to a 3 blade Campbell fixed prop.. this was an early 80s IOR 2tonner.. we lost a good .5 knot overall under some conditions, none noticeable once the breeze was up. The improvement in smoothness and reversing power was very noticeable.
On our current 35 footer we recently went from a 2 blade michigan to a 3 blade Max. The gain in smoothness and quiet is worth it alone.. I reckon that in light to average average conditions we're up the better part of a full knot. Again the difference is less noticeable once fully powered up. In light air it's 'huge' .. And while we've always been able to maneouver in reverse OK the boat gains steerageway much sooner with the max, with less (but still useable) propwalk.
I don't have spreadsheets to back all this up, but these were our observations.
post #18 of 48 Old 11-05-2011
Fstbttms's Avatar
I'm relatively certain the difference between a fixed-blade prop and a folding or feathering prop is more than a tenth of a second per mile on any boat.
Fstbttms is offline
post #19 of 48 Old 11-05-2011
blt2ski's Avatar
This was probably a "10th of a knot" The previous owner of my boat mentions something similar for speed gains under sail as Faster did, about 1/2 knot. A few folks that have "OTHER" props that have been on my boat comment about how smooth, lack of prop walk etc, the max prop is in reverse.
Marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
post #20 of 48 Old 11-05-2011
On my Tartan 27 I had a two blade fixed and went to the three blade fixed from Indigo and saw a very small loss of seed, but a great improvement under power - my yacht club's channel has nearly a 4 knot current on a moon tide. I then switched to a 2 blade feather. It maintained the boats performance under power and I probably gained .3 kts under sail.
SkywalkerII is offline
Feathering Prop vs. Fixed Blade Prop Benevento Pacific Seacraft 70 02-11-2011 07:52 AM
Feathering Prop Dmarina Gear & Maintenance 9 09-07-2010 04:33 PM
Folding vs. Feathering Prop? MJKahn Hunter 4 08-06-2007 09:54 AM
Hydralign Feathering Prop BELLATRIX1965 Gear & Maintenance 2 01-01-2007 09:25 PM
Zincs for Sail Prop feathering prop jrbarn Gear & Maintenance 4 09-20-2006 10:40 AM
