11-06-2011
Senior Moment Member
Originally Posted by Faster
I'd grind off the hull in the contact area of the 'pad' plus a couple of inches all around it... be sure to radius/router the upper edges of the pad to a reasonable curve (minimum 1/4" radius) for later.
Bed the pad in a thickened epoxy and tool the excess at the edges against the hull into a nice fillet.(using a gloved finger or a tongue depressor stick). Let it set up some. Then glass over the pad with say, several layers of six oz cloth and epoxy resin for a good seal. The rounded corners will let the cloth sit cleanly on the pad rather than tend to lift as it goes over the edges. Glass down and over onto the extra area ground off before. Let cure, give a good scrub wash afterwards and slap on a coat of paint (maybe sand and paint the whole area while you're at it.. it'll look great)
Remember to caulk the mounting screw holes to keep it all dry.
Faster has it pretty well covered but I'd like to expand on one of his points - it's something I've learned from hard experience. The combination of the radius on corners and the weight and type of glass fabric is where difficulties often arise. The heavier the fabric, the greater the radius needs to be. If you use something very light, like 6 oz. cloth, 1/4" radius should suffice. If you are tempted to go with a heavier weight fabric or a different weave like biaxial or a lightweight roving then you will have to make a considerably larger radius on any corners you want the fabric to drape over smoothly.
Light fabrics are slow to build thickness with - more layers needed - so you always have to choose an appropriate combination of fabric and radii for each situation.
Some final considerations - cloth is the nicest to handle and gives the best finish. Also, weight for weight, it is the strongest as well, since its finer weave holds less resin. Its only real downside is that, as noted, it is slow to build thickness with so it is more time and $$ consuming.
Don't let it intimidate you - it's really pretty easy. It just takes some experience. I find wallpapering to be far more difficult.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
