Like Tree1Likes
  #11 (permalink)
Old 11-06-2011
Snboard976's Avatar
S/V Sabbatical
Snboard976 is on a distinguished road
Some of the tape was either scotch or 3m brand, there was some that was another brand. I believe its called painters tape. The fact that it was on a vertical surface made it difficult to soak. The varnish on much of it may have also been a confounding factor.
Chad Gleason
s/v Sabbatical Pearson 365 Hull #32
  #12 (permalink)
Old 11-07-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
That's the stuff - Scotch brand IS 3M by the way. The varnish covering would certainly seal it off from the WD40.
If it happens in the future, try peeling a bit up and getting the WD under the tape, on the glue and slowly peel it away, squirting or dribbling it on as you go. I have sometimes had to work my way along like that.
sigmasailor likes this.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
  #13 (permalink)
Old 11-07-2011
Beersmith's Avatar
Sailing to surf
Beersmith is on a distinguished road
I have to remove blue tape often on my rebuild. WD40 + scotchbrite pad works wonders
My boat rebuild/sailing blog:
Please read and provide comment to my entries!
  #14 (permalink)
Old 11-07-2011
jjablonowski's Avatar
jjablonowski is on a distinguished road
I'd try a product called "Goof-Off" from your local paint store. Based on Xylene and Methyl Carbitol.
Joe - Catalina 25
  #15 (permalink)
Old 11-08-2011
jfdubu is on a distinguished road
This is precisely why I always use cheap electrical tape for paint lines. It's flexible, hopes a clean line and removes easily. I've had it on my waterline for weeks and it comes off with no residue. $1.00 a roll at Job lot.
John
  #16 (permalink)
Old 11-08-2011
meteuz is on a distinguished road
I was able to peel off a considerable about of tape using a credit card in one hand to keep it coming up. The credit card seems to be the best scraper.
It's funny how the credit card is the most expedient tool to fix most problems!
What the HELL is going on?? MIKEMCKEE Politics/Religion/War/Government 12 11-03-2011 08:48 AM
What the hell did I just do!?!? xymotic Introduce Yourself 3 09-01-2011 07:33 PM
ASA 101. Hell yes. RatHatDiver Learning to Sail 22 08-11-2011 10:13 PM
What the hell? eherlihy General Discussion (sailing related) 16 07-19-2011 08:28 AM
Blue Tape SailingFlorida Gear & Maintenance 22 10-23-2008 04:53 PM
