Old 11-08-2011
L124C's Avatar
L124C is on a distinguished road
Glazing compound kicking too fast!
Just painted the Port side of my hull, and used 3M Acryl-Blue Glazing Compound to fill scratches. The instructions said it drys in 25 minutes at 72 degrees, and that you could fair entire panels with it if needed. I was applying it outdoors on a 70 degree sunny day with almost no wind. It kicked almost instantly. I could spread it once, maybe twice, but if I brought the spreader through it a third time, it turned into a mess. There is no way I could have faired a large surface with it. I'm thinking that it's formulated for shop conditions, and that because I was in the sun and there was a little breeze, it kicked too fast. I'm going to try the red compound which calls for dying overnight. I'll bet it will be more user friendly for outdoor use, and that I can sand it within hours under the same conditions. Thoughts?
Old 11-08-2011
garyguss is on a distinguished road
Dying overnite is kind of overkill
Old 11-08-2011
tommays's Avatar
I used systemthree and was pretty happy but you do not get a whole lot chances at spreading it
The problem with any filler is what your putting on top of its compatibility and HOW long well the filler is going to handle hull flexing and dock bumps and stay on the hull
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 11-10-2011
Capt Len is on a distinguished road
I don't do much plastic but i bet cool and shade would help on smaller areas at a time.Once the base has heated ,poof !
Old 11-11-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Glazing compounds are intended to fill scratches and pinholes that are just a bit too much for high build primer to fix. You can't "sculpt" them in ANY way. One quick wipe of the spreader should be all that is needed or you are overusing them. It sounds like you should be using a more "bulk" filler like epoxy and talc or balloons.
If you overuse the glaze fillers they will not stay in place later - whatever you are filling will crack or loosen up under the finish. After sanding them you should only have the faintest traces of them left - little speckles and hazes of colour. Any more than that and it is too thick.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Old 11-11-2011
JedNeck's Avatar
JedNeck is on a distinguished road
Also if your outside in the sun the surface temp of the hull is probably well above the 70 degree ambient.
Old 11-12-2011
L124C's Avatar
I was filling hairline cracks as you describe. No "sculpting" was involved (I have two part fairing compound for that). The problem was in covering a wide area. The material I had just applied had already kicked and would peel off as I applied new material to an adjacent area. I overcame this by doing spots and allowing them to cure fully before doing the adjacent area. If I had 30 seconds of working time, I could have quickly covered larger areas. I could have never faired an entire panel in one shot as described in the directions (and didn't need to), so I suspected the product was not performing as intended, probably due to conditions. I was not using it in direct sunlight, and don't think the surface temperature was above 70. I'll try the red and report back. I'll also report if it all falls off the first time I bump a dock! The funny thing is... I originally had the red (which is less expensive) and thought I couldn't wait overnight for it to cure!
Old 11-12-2011
mike dryver is on a distinguished road
cut back on the catalyst a little to give yourself more working time. working direct sun will heat hull as posted earlier.
Old 11-12-2011
SloopJonB's Avatar
Glaze fillers come in a tube and are not two part in my experience, they are lacquer based.
Pearson Window Glazing melusina32 Pearson 2 05-11-2010 05:10 PM
Re-glazing ABI bronze ports walburgh Gear & Maintenance 1 06-04-2009 01:49 PM
Redwing 30 glazing spline irtrimble C & C 0 03-30-2007 06:50 PM
Kicking off a dream ergoodrich Learning to Sail 2 10-08-2005 12:05 PM
QUestion about epoxy. What is "kicking"? duffer1960 Gear & Maintenance 3 05-02-2005 12:28 PM
