11-10-2011
Originally Posted by BethandNorm
I am adding an anchor light to the mast of my 1975 C&C25. There exists a masthead light and foredeck light, so the mast is wired with 3 conductor cable ans has a bulkhead connector on the deck by the mast step. I need help / sugestions to find a suitable 4 conductor connector and appropriate cable. I purchased a 4 pin connector advertised for this exact application from Catalina Direct; however, the largest cable diameter it can accept is 1/4 inch and that would be a stretch! One thought I had was to use a strain relief at the deck and put a small terminal strip below inplace of the plug type connector. The other was to add a second 2 conductor cable and connector for the anchor light alone. Any ideas would be greatly appreciated.
Here's my suggestion. Get one of these, a Davis LED mega light,
hang it from the boom and forget the light at the top of the mast.
Ron Paul 2012
"wikijar"
