trailer lighting?? - Page 2 - SailNet Community
 2Likes
post #11 of 16 Old 11-12-2011
LakeSuperiorGeezer's Avatar
Take an alligator clip, one of those clips with a long nose on it, and reach inside the trailer connector with a hot wire from a battery and also of course connect the ground. See if things light up. If this works and you have a good ground from vehicle to trailer then consider relays and be sure to fuse the circuits.
LakeSuperiorGeezer is offline
post #12 of 16 Old 11-12-2011
Superior Sailor
Squidd's Avatar
It may not hurt to check that the bulbs are "in place" and haven't rattled out of their sockets due to shipping, handeling etc...
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
post #13 of 16 Old 11-12-2011
What you need to do is test the continuity of the ground. You need a multimeter for this, on ohms range.
Check that you have around 0 ohms (might be 1 ohm, no higher) between the vehicle ground and that pin on the car's 4 way connector.
Then check between the trailer's ground pin and anywhere on the trailer chassis where you can touch exposed metal.
There should be a wire from the trailer's ground pin, to the trailer's chassis. If this is broken (can be broken internally so it looks OK) or has a bad connection this will stop all the lights working.
These things age quickly from regular dipping in water!
There's only so far you can go with a test light. A multimeter is a much more powerful tool.
MarkSF is online now
post #14 of 16 Old 11-12-2011
Nah, Use a piece of wire with two bare ends and look for sparks. (just kidding)
Never Forgotten
bubb2 is offline
post #15 of 16 Old 11-12-2011
Sparks
In reality, I have done this, but the problem is the way I do it, I usually blow a fuse.
post #16 of 16 Old 11-13-2011 Thread Starter
robbieland's Avatar
well, thanks so much for the suggestions. i couldnt make anything happen, so i purchased the magnetic temp lights, which dont need the ground. plugged them in and still nothing. so, guess the tester was lying. so here i sit on land missing my trip and ready, somewhat, to begin tomorrow on car plug issue. thanks again.
robbieland is offline
Lighting Ground? 1970Columbia34 Gear & Maintenance 4 02-28-2009 10:15 PM
Cockpit Lighting SVCarolena Gear & Maintenance 27 09-03-2008 11:33 PM
Cabin Lighting Dmarina Gear & Maintenance 20 07-07-2008 05:26 PM
Cabin Lighting Freesail99 Gear & Maintenance 24 06-29-2007 11:29 PM
Lighting Up the Interior Sue & Larry Gear and Maintenance Articles 0 01-27-2002 08:00 PM
