-   -   trailer lighting?? (http://www.sailnet.com/forums/gear-maintenance/80677-trailer-lighting.html)
robbieland 11-11-2011 09:02 PM
trailer lighting??
im taking, or hopefully taking my , new to me, O'day Daysailer 2 up the road, approximately 200 miles to a lake on Sunday. everything is ok to go except the trailer lights. i bought new ones, since the lights that came with boat and trailer didnt work. now i have installed the new system, following all directions and nothing. nothing works. ive tried various test, re-wiring, etc. and still nothing.
i bought a continuity or the likes tester, which alligators to one section and needles the connections. and from my car plug everything works: one lights when lights on, second lights with left turn indicator and third lights with right indicator on. so seems that is good. the wire set-up is four plug with ground wire screwed thightly to trailer frame, two wires back to left light and a ground from that section screwed tight to trailer frame and same for right side. what am i missing? any ideas? anyone? thanks for any thoughts! this is very frustrating and time consuming.
bubb2 11-11-2011 09:15 PM
did you screw the ground to "bright" metal on the trailer frame? Rust or paint can cause your problem. check the continuity on the ground.
Squidd 11-11-2011 09:31 PM
What Kind of lights are you using..? Usually the lights ground thru the mounting bolts.... and the wires are for power..
Green is right (stop/turn)
Yellow is Left (stop/turn)
Brown is both (clearance)
White on the 4 way plug is ground to frame..
Unless you have the rubber mounted sealed units, then they supply a white wire for grounding to frame..
Make sure wires or bolts go to "shiney metal" as mentioned..
Also if trailer is a "Tilt" type....make sure ground is continuous thru hinge point (dissassemble and grind "shiney" or add a jumper for ground..)
robbieland 11-11-2011 11:14 PM
the lights im attempting to use are brand named Blazer International , which are submersible Trailer lighting kit i purchased from Walmart. it has the four wires extending from plug to lights. two cords to each light, yellow and brown to left rear and green and brown to right. a white ground with eye loop extends from each light. i tried attaching the ground cords to mounting bolts, but since that didnt work, i drilled holes into trailer and bolted. the front ground as well as back two are securely bolted to clean solid part of trailer. the trailer is not a tilt.
bubb2 11-11-2011 11:25 PM
Take a piece of wire, attach it to the ground at the trailer tongue. Then try to find a spot on the tow vehicle to ground it to (bare spot on vehicle frame) If you get lights then the plug on the vehicle side does not have a good ground.
robbieland 11-11-2011 11:39 PM
thanks!! ill give that a try tomorrow.
bubb2 11-11-2011 11:58 PM
could be nothing more than corrosion on the ground post of the plug. Make sure that's good and shinny also.
LakeSuperiorGeezer 11-12-2011 01:26 AM
Ground?
This is the way to trouble shoot the problem. It is my experience that the ball and hitch do not make a good ground. That ground wire inside the 4 pin plug is needed for lights to work and the vehicle side has to go to a good ground while the trailer side also has to be grounded to the trailer frame. The other things I can think of are the turn signal flasher which might need to be changed for a heavy duty one, or if the tow vehicle uses a computer for controlling the lights, you will need relays for left, right, and tail lights. Check the owner's manual. Those computers will cause really strange things to happen, so go to Radio Shack and buy three 12 volt relays and wire them in. I had to do that on my 1995 Crown Victoria. If your vehicle has a trailer package, the relays should already be there. I have a 1995 F350 that has relays even for the backup lights.
CorvetteGuy 11-12-2011 08:12 AM
are there bulbs in the fixtures,,,,sounds like a grounding issue
PaulfromNWOnt 11-12-2011 10:37 AM
You know, that was the first thing I thought as well, but I imagine those kits from Wally World are fairly complete.
It does sound like a ground issue unless some of the lights work in which case you'll have a little more rooting around to do.
