Old 09-19-2003
maestro is on a distinguished road
home built dink
Anyone have good luck in getting plans and building a home made wooden tender?? I don''t want to go out and buy an inflateable, and I like woodworking.
How tough is this?? What''s the best type of dingy to build ( I''m looking for something in the 7-9ft range)
Any suggestions??
Mike C.
Old 09-19-2003
soapstone is on a distinguished road
home built dink
If you can find the time, take the wooden boat building course at Mystic seaport, I did and recommend it highly. One of the things they teach is how to build a boat from a simple table of offsets, and not a cookie-cutter pattern that the kit builders sell.
IMHO the traditional boats are a lot prettier, and maybe faster, but heavier than a stitch and glue cookie cutter thing.
Old 09-23-2003
pravel is on a distinguished road
home built dink
I built a D4 Pram from plans from bateau.com.
It has an option to make it sailing capable and I went with that thinking I might want the capability and not wanting to limit its potential. The result was a fine boat and much gained experience/confidence with fiberglass/epoxy. However, it is too heavy for one person to lift and is a tad long to stow on deck on my Pearson 30. When I build again, I will go for the lightest fiberglass/epoxy construction possible. There is a nesting 10 footer that is very interesting. Each half weighs less than 45 pounds and it stows in less than 5 feet long.
Regards, Jim Pravel
1973 P30 SamaSama
Chesapeake Bay
Old 09-23-2003
msl msl is offline
msl is on a distinguished road
home built dink
Look at this month''s "Good Old Boat" issue. They show how to build a ''nesting'' dink. Neat concept that allows storage on deck of a right sized dinghy.
Old 09-23-2003
928frenzy is on a distinguished road
home built dink
An alternative is an 8'' Porta-Bote, which folds to a space of 8''x2''x4". They can: hold two adults, be powered by oars or a small outboard or even a sail, will not puncture, and float even when full of water!
I have the 10''6" version which holds three adults. They also make a 12'' version that holds four adults. Check them out at: www.portabote.com
~ Happy sails to you ~ _/) ~
Old 09-24-2003
paulk's Avatar
paulk is on a distinguished road
home built dink
Buy a copy of Woodenboat. There are at least a dozen different ads for dinghy kits and plans of different types and construction methods. The Woodenboat website is a good place for additional - and knowledgeable - info as well.
Old 09-28-2003
Robinl is on a distinguished road
home built dink
I built the D4 and have been extremely happy with the results. I also built a couple of sea kayaks and compared to building those the D4 is a breeze. I built the sailing version and the thing sails and rows really well. Good luck!
Old 09-30-2003
Figment is on a distinguished road
home built dink
The Good Old Boat article on the cedar strip nesting dinghy was a good one. I''ve since had correspondance with the builder, who says that the reduced-size version wants more stability. I also suspect that the rounding of the chines to accommodate the cedarstrip process robbed some initial stability as well.
Nevertheless, I''m a big fan of Dave Gerr''s Nester design.
I recently built Steven Lewis'' "Dinghbat", a 8''x4'' taped-seam pram, from plans obtained free from the Duckworks site. I''d suggest building the newer V-bottom design, as my flatbottom version wants some stiffness in the bottom. I also suggest that one fudge the plans a bit to obtain at least 3" more freeboard, though this will likely require an extra sheet of plywood. I haven''t weighed it officially, but I can tote it across the boatyard on one shoulder. It rows well, and I suppose it would take a 2.5hp motor with ease.at
Bateau.com has some excellent plans.
CAUTION: Building one''s own boats is thoroughly addictive. This will NOT be the last boat you build. Dinghbat is my third, and I''m already sifting through plans for number four.
Old 09-30-2003
tsenator is on a distinguished road
home built dink
Figment,
How does the dingbat sail? I''m also trying to decide what 8 foot dink to build (I''m just looking at the simple glue and stitch designs)
the designs I am looking at are:
The D4 (or maybe newer refined D5)
http://www.bateau.com/plans/small/D5.php3
The Dixi Dinghy or the Argie 10
http://www.dixdesign.com/dinghies.htm
The Glen-L Eight Ball design
http://www.glen-l.com/designs/sailboat/8ball.html
They all look pretty similar....any comments from anyone....any design sail better than another?.....I am looking at possible trying to have it sprit or gaff rigged because I have heard that will perform a bit better than a similarly sized marconi rigged sail
Old 10-01-2003
home built dink
thanks for all the replys.
I just bought plans for the D4 pram as well as an 11ft. skiff...my boat comes out of the water next week for the season, so I''ll have time to do at least 1 of the 2 boats before it gets too cold.
HOME SCHOOLING CHILDREN MIA herSailNet 22 09-24-2006 02:11 AM
Home School Help GordMay herSailNet 1 09-25-2005 03:15 AM
Home Depot selling Reverse Osmosis Watermaker''s chuck711 Gear & Maintenance 6 08-14-2003 03:08 AM
Earn for clerical job at Home ravibhai Boat Review and Purchase Forum 2 04-30-2003 05:36 AM
buying first boat jerrycooper14 Boat Review and Purchase Forum 21 04-23-2002 02:15 PM
