Bus-bar - SailNet Community
post #1 of 3 Old 09-19-2003 Thread Starter
Bus-bar
have about 10 lines to this positive bus bar and only have current to two !! any ideas what the problem is and how I can fix?
thanks
duke
duke is offline
post #2 of 3 Old 09-19-2003
Bus-bar
Duke; Is the electrical continuity of the buss bar intact? Are all connections clean and tight? Just went through the old loose connection gig myself. Regards, George
geohan is offline
post #3 of 3 Old 09-20-2003
Bus-bar
Definitely loose or corroded connections - either at the bus bar or between it and wherever you are measuring for voltage (load); unless there is a fuse hidden somewhere in the circuit(s).
Itís almost always the connections and/or terminations (splices, terminals, fuseholders, etc).
Regards,
Gord
GordMay is offline
