11-15-2011
Senior Moment Member
Originally Posted by TomandKarens34
At the minimum, eight, twelve inch long, 1 inch dia. threaded stainless rods, the keel drilled and tapped, then the rods encapsulated in epoxy by filling the holes before they are screwed in. Then 1/4" 2X2 stainless washers nuts and lock washers tightened to around 90 to 100 ft. lbs. anyway. And that would be the minimum.
This is major overkill - we're talking about a Catalina 25! Just by way of comparison, my Columbia 43 - 10,200 Lb keel has 10 X 3/4" keel bolts.
Is the keel on a Cat 25 even 12" deep? No matter, you'd be 1/2 way through it no matter what.
Call Catalina and follow their advice.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
