11-14-2011
Senior Moment Member
Originally Posted by MarkSF
Painting over the existing, which seems to be a pattern formed in the fibreglass, that has then been painted over with ordinary paint.
I've used Sikkens Anti slip deck paint twice with very good results. It can be diifficult to get - last time the local Sikkens people didn't even know about it - I had to get it shipped from an Ontario retailer.
It goes on thin & flat, no trouble with it puckering, roller dragging or anything like that. It has a very fine abrasive or particulate in it that stays in suspension well and gives a very grippy surface with no visible texture. It is thin enough that I rolled it over a fairly bold nonskid with a thin foam roller and had no trouble with the paint reaching the bottom of the pattern.
AFAIK it only comes in 4 colours - white, grey, beige & blue. The grey is too dark for my taste - very "battleship". I used 3 parts white & 1 part grey which gave a nice pale dove grey - enough to cut glare and show definition in the non-skid panels but almost identical to the white gloss areas from any distance. Its texture is fine enough that it doesn't hurt to kneel on it, even bare legged but it will "sand through" jeans if you spend a lot of time kneeling on it - rebedding hardware etc. I have NEVER slipped on it.
I can highly recommend it.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
