Like Tree2Likes
Old 11-14-2011
Doupirate is on a distinguished road
OGM anchor light/ water condensation
Water vapor transpires through the «putty» they stuck around the connexion wire. That putty does nevertheless meet the USCG waterproof requirement: it is waterproof to liquid water. Water vapor hence gets trapped inside the light.
Drilled two holes in the 450$ light (after customs fees and transport in northest Canada) to have the condensation evacuated.
Dried! No more waterproof though!
Old 11-15-2011
In addition, whenever I turn the light on, I can no more listen to the radio: interference.
I am trying to find their ferrite bud to put on the wire.
Really disappointed with that product.
Old 11-15-2011
Captainmeme is on a distinguished road
ferrite beads, (I would use a core) Filters | Ferrite Cores for Cables and Wiring | Digi-Key
Try looping the nav light power cable around a core several times. Also put a core on the power cable to the radio.
Old 11-15-2011
Vasco's Avatar
Warm Weather Sailor
Vasco is on a distinguished road
Try one of these about $30.The brightest anchor light in the anchorage. I put the pvc pipe on to protect the delicate wires that come from the led's.
rikhall likes this.
Rick I
Toronto in summer, Bahamas in winter.
Old 11-16-2011
My radios are powered by a separate circuit. I will hook this by the fuse box:
Old 11-16-2011
An interesting experiment would be to temporary power the nav light on a separate battery from the radio to see if the interference stops. Your nav light may be doing double duty as a radio transmitter.
Old 11-16-2011
Prior to purchasing the filter, I hooked the light on a power pack at home. I then took my portable VHF, turned the volume high and moved it close around the light.
........silence
No electro-magnetic emission.
So I concluded blocking the ripple interference on the power side should be sufficient.
Old 11-19-2011
rikhall's Avatar
old guy :)
rikhall will become famous soon enough
I have the exact same one mounted at the top of the mast and it has always been the brightest where ever we have anchored. Bebi Electronics have been so good to deal with. Answer email very promptly and are extremely helpful. Even when I was not sure what I wanted or needed.
Rik
Irwin Citation 34
Old 11-19-2011
rbrasi's Avatar
rbrasi is on a distinguished road
Rik
Link?
1968 Cal 2-30
Sandpiper 2
MDR
Old 11-19-2011
mitiempo's Avatar
Bebi Electronics-Home of the Finest Marine LED Lighting Products on Sea (or Earth)!
rikhall likes this.
Brian
Anchor light junkrig Seamanship 28 09-19-2011 11:25 PM
LED anchor light kwaltersmi Gear & Maintenance 13 10-29-2010 12:39 PM
condensation water in fuel tank ArgleBargle Gear & Maintenance 4 11-03-2009 08:24 AM
Anchor light sailor12345 Gear & Maintenance 2 07-23-2002 02:48 AM
Anchor light syrenab General Discussion (sailing related) 1 04-15-2001 06:39 AM
