Old 11-16-2011
noelani is on a distinguished road
stainless steel cleaning
hi everybody i have just arrived back in the USA to find rust stains on the stainless steel. i remembered somebody mentioning a cleaning chemical on this forum. does anybody remember what it was?
Old 11-16-2011
mitiempo's Avatar
Spotless Stainless Home - Spotless Stainless Removes Rust, Protects Stainless Steel
Brian
Old 11-16-2011
sawingknots's Avatar
sawingknots is on a distinguished road
i've alwas just used a regular fiberglass cleaner-wax,works for me and i usually have some onboard anyway
Old 11-17-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Autosol
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Old 11-18-2011
QuickMick's Avatar
QuickMick is on a distinguished road
Ive found most cleaners dont live up to the advertisements... lol, but I have had pretty good luck with Naval jelly... insert link here: Phosphoric acid - Wikipedia, the free encyclopedia
but would note that it is VERY caustic, so if your surface isnt actually 316 or whatever but chromed/plated it very well may eat your plating off of what you are trying to clean.
good luck
Q
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 11-18-2011
SloopJonB's Avatar
but would note that it is VERY caustic, so if your surface isnt actually 316 or whatever but chromed/plated it very well may eat your plating off of what you are trying to clean. good luck Q
Good luck indeed - Naval Jelly is a corrosion dissolver, not a polish. AFAIK, phosphoric acid is THE strongest acid there is.
If you don't believe me, check out the first season episode of Breaking Bad when Jessie fails to follow Walt's advice and tries to dissolve the villain at home in a bathtub of phosphoric. Hilarious if you enjoy black (VERY black) humour. Also a pretty good dramatization of the power of phosphoric.
I stand by my recommendation for Autosol - try it.
Edit: My comments about Phosphoric acid are incorrect - It was Hydrofluoric acid I was thinking of - it will dissolve GLASS. The other comments stand.
Old 11-18-2011
mitiempo's Avatar
Naval Jelly is a rust remover, not a polish, as Sloop posted.
Brian
Old 11-18-2011
Charlie B's Avatar
Charlie B is on a distinguished road
I use Turtle Wax's Chrome Polish, available at WalMart. (of all places) It works great, as it's designed to dissolve rust and it's a polish as well. I have used it on some very rust stained stainless, by the way and it's fast without a lot of rubbing.
1968 Morgan 24/25 S/V My Fair Leslie
Cleaning and treating Stainless Steel sailingdog Gear & Maintenance 43 03-31-2011 03:22 PM
Stainless Steel Bottom cabron99 Gear & Maintenance 8 05-19-2010 04:37 PM
Stainless Steel... merttan Gear & Maintenance 14 04-12-2008 07:59 PM
Combination stainless steel chain/ galvanized steel anchor Grigrigrigoris Gear & Maintenance 11 07-03-2005 03:46 PM
stainless steel maintenance psemme Gear & Maintenance 0 12-09-2001 10:20 AM
