J24 Bilge Cracks - Page 4 - SailNet Community
post #31 of 32 Old 12-25-2011
Yes - and it's no big deal
Originally Posted by mnky View Post
Just wondering if anyone has seen cracks like these in J24s. They are only in this part of the bilge- the rest is solid. It's a 1983 boat, bilge was full of water and has been sitting on a trailer for months, however no sign of water leaking out around keel.
I have 2391 and mine has this too - in fact it looks like you took a picture of my keel. Virtually every boat in my local fleet has these cracks and they're newer than mine. My keel stays dry while it's in the water (fresh water, all sailing season - not dry sailed).
I had a certified marine surveyor look at my boat before I bought it and it was pretty much a waste of money. He freaked out about the cracks because they were cracks, but had no other points of reference or information that factually established why they would be a bad thing. Then I talked to the owners in my fleet.
The consensus view of the owners in my area is that you have you have to ask yourself three questions. 1) Are you anal retentive? 2) do you have money to burn? 3) Do you have too much time on your hands? If the answer is yes to all three, that you should do something about it. The only caveat is if you had massive cracking around the keel/sump mate point and were taking on water. But your pictures show it's dry.
You can buy the kit for this from WaterLine or do it yourself. The view of a boat yard who has done many of these overhauls regards this as a structural repair. So if you do decide to do it and you know you will never sell the boat then doing it yourself might make sense. If you're going to sell it someday, the few bucks more for the kit also buys you paper work that says you didn't compromise integrity. Might make it easier to sell.
The repair looks really cool after it's done. If someone offered to do it to my boat for free I'd take them up on it. The rest of us have decided to go sailing instead.
Finally, I have to laugh about the J24 being a lightweight boat. I'd ask if you'd ever seen one? Compared to a bunker oil barge, yes its a light boat. But even in the 80's it was a beefy boat - it's almost 1,000lbs heavier than a Moore 24. And the Martin 242 is 600 lbs lighter. Since my boat is named after a woman, she'll take the complement about being sevlte.
j24j is offline
post #32 of 32 Old 05-15-2012
Re: J24 Bilge Cracks
Replying to one's last post may be a sin greater than high-jacking a thread - I apologize in advance.
I found that when I tried to torque my keel boats to spec, the not-vermiculite material in my sump wasn't able to be tightened. Her keel bolts were all finger tight - yikes! The material that was in my keel was a sand/epoxy mixture that has zero structural strength. Tightening them just made the sump mush.
The junk in my sump stuff smelled like epoxy resin if cut, and when hit with a chisel, chipped out like rock candy. After all of it was out the total weighed maybe 10 lbs max. It also floats in water. I found a number of tie wraps in remarkably good condition and what I think was a chunk of wood that had thoroughly rotted in the sump. The upside is that the keel bolts were in bright condition - which I thought was remarkable.
I'm just about done rebuilding the sump with the waterline systems kit, and it will be extremely strong. My guess right now is that it will weigh the same. The work itself wasn't too bad since the junk chipped right out with a wood chisel and a rubber mallet.
Bottom line for me was that my sump had lost its structural integrity. The other thing that I took care of was my cabin sole. In the heat of racing years ago the floor cracked out, undoubtedly due to being jumped on. Upon removal, I found the balsa core of it that was completely rotted. I did a great deal of other maintenance work this winter and found the rest of the boat to be surprisingly free of balsa rot overall with this profound exception.
I have no idea if the rest of the fleet can tighten their keel bolts, but I know mine are going to be to spec.
j24j is offline
Installing automatic bilge pump in series with diaphram bilge pump... sweetdreamyamaha Gear & Maintenance 6 11-07-2009 11:36 AM
Santana bilge stress cracks larlei Gear & Maintenance 1 09-07-2009 11:49 AM
Shallow Bilge, Bilge Pump Switch labestia Gear & Maintenance 1 07-10-2009 02:40 PM
Gel Cracks on 309 Siamese Gear & Maintenance 4 09-30-2008 01:50 PM
cracks on eck richb Boat Review and Purchase Forum 1 08-16-2001 01:47 PM
