Like Tree1Likes
Old 11-18-2011
Windkiller's Avatar
Windkiller is on a distinguished road
bowsprit wood
howdi all
I was thinking of putting a wee bowsprit on my Danica 16..for fun and maybe rigging another headsail . I'd use a small roller furler on it with a jib I have that has a wire luff to make her a wee cutter (despite the mast placement)She has a fair amount of weather helm right now and I've heard from others that this can work on these types of boats(nordicas)
I'd put the jib up on a wire to clear the pulpit(the existing jib is rigged this way too)
I was thinking of something extending beyond the bows about 2'-2.5' and about 2" in diameter with a total length of about 44"
I plan to stay it as it should be (down and to both sides) and likely sit it right in the anchor roller unit (remove the roller, it's 2" wide..poifect!)
I was wondering the best wood to use (in price and strength) I've heard douglas fir would be good, I have a piece of mahogany that would do but it's pretty heavy to hang off the bow and I've heard it's not the best outdoor wood. teak seems to be pretty pricey.
I'd be doing this as a fun project for kicks and design it so it's either reversible or easily convertible
hmmm any idears?
bowsprit wood-cute-danica-side-view-small-.jpg   bowsprit wood-cole-hauled-port-2.jpeg
Old 11-18-2011
rugosa's Avatar
rugosa is on a distinguished road
What about aluminum or stainless steel? No wood to maintain & you could design your anchor roller into it.
Old 11-18-2011
Siamese is on a distinguished road
Can't go wrong with teak.
But...I'd question making her into a cutter. I'd suggest researching the effect of adding that second headstay on your backstay tension. In the end, you may find that your boat doesn't point as well and is fussier to trim.
Why not add the bowsprit and ditch the roller furling. IMHO a roller furler on a 16footer is like teets on a bull. Why not spend your money on a larger headsail and a second, smaller one for the heavy days?
Old 11-18-2011
emoney's Avatar
emoney is on a distinguished road
First of all, that may be the cutest little thing I've seen!
Now, back to the wood. Mahogany has been used for eons on boats, so don't be afraid to "use what you got". The key to mahogany, imho, is the grain cut. I used a 1/4sawn piece to fashion a tiller, because I believe that to be strong enough to withstand the pressures of the helm. Of course, finishing the wood properly will aid in it's longevity. That and not being lazy about maintaining it. I used several heavy layers of Spar Urethane and it seems to be holding up fine.
Old 11-18-2011
dabnis is on a distinguished road
For what is is worth, take it from one who was always changing things "to make it better",
many times making it worse or with no gain. I think for the most part someone put in a lot of time and effort when coming up with the original design. Suggest that if you make changes they are easily reversed back to the original design. Perhaps the cost involved could go towards a new outboard?
Dabnis
Old 11-18-2011
Boasun's Avatar
Boasun will become famous soon enough Boasun will become famous soon enough
After you put a bowspit on your Danica, think about shifting your mainsail to a gaff headed sail...
Aside of that you do have a sweet looking boat.
1600 Ton Master, 2nd Mate Unlimited Tonnage
Maritime Instructor
S/V Rapture
Old 11-18-2011
CharlieCobra's Avatar
On the hard
CharlieCobra has a spectacular aura about CharlieCobra has a spectacular aura about
Sitka Spruce.....
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
Old 11-18-2011
jimgo is on a distinguished road
I'm with the others - that's a REALLY cute boat! I bet she's a lot of fun. I don't know that I'd be looking to change her.
- Jim
1984 Catalina 25 Swing Keel, Standard Rig
Home: Western Philly 'burbs
Boat: (current) Toms River | (next season) Up in the air
Old 11-18-2011
kwm kwm is offline
kwm is on a distinguished road
Dabnis
This... you learn a lot when you make a change and find out it does or doesn't work.
Old 11-18-2011
On the hard
^^ For sure ^^ Adding a sprit might introduce a bad case of Lee helm, which is really bad on a sailboat.
Bellingham, WA.
Bowsprit glegh Sailboat Design and Construction 5 04-13-2009 11:08 AM
Selden Bowsprit CGMojo Gear & Maintenance 4 02-22-2008 10:46 AM
Replacing wood "curtain" with wood door in head area? Catalina 27 7tiger7 Gear & Maintenance 25 07-29-2007 11:24 PM
Fitting a bowsprit to a First 40.7 jlaake Gear & Maintenance 4 03-05-2006 10:11 AM
Bowsprit on a Peterson 44'' a_oros Gear & Maintenance 0 05-21-2002 11:48 AM
