Like Tree1Likes
  • 1 Post By tommays
Old 11-18-2011
Barquito's Avatar
Barquito
Barquito is on a distinguished road
Bulkhead repair
I have some water damaged wood on my bulkhead. It is under the chainplates. The chainplates, however, attach to a seperate knee on the hull, not the bulkhead. How can I repair the (maybe 4"X4") corner of the bulkhead?
Old 11-18-2011
QuickMick's Avatar
QuickMick is on a distinguished road
got pics? might wanna make a small investment in this:
Amazon.com: Spurr's Boatbook: Upgrading the Cruising Sailboat (9780070605541): Daniel Spurr: Books
has a great chapter on repairing replacing chanplates... i would be a wee bit concerned that the damage may affect a greater area than is readily visible...
good luck
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 11-18-2011
tommays's Avatar
I will post some pictures tonight as i replaced a pretty big section of one of Seafevers bulkheads which holds a chainplate and it has passed the its pretty dam windy test without issue
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 11-18-2011
Barquito's Avatar
Barquito
I might have made my OP confusing. The chainplates are not connected to the bulkhead. That was just the source of the water. This is almost a cosmetic repair. It is just a matter of hacking out a chunk of the wood and replacing it with something similar. I'm just not sure how to do carpentry on a bulkhead already installed in the boat.
The rest of the bulkhead feels pretty solid.
Old 11-18-2011
tommays's Avatar
did not look that bad
Probing found it to that BIG and a piece of guide wood with a 45 deg bevel to guide the Fien tool made cutting easy
which left solid wood
A new piece as fitted in and G-FLEX was used for the wood to wood and the rest was taped back to the hull
Some strategic painting left things about as good looking as could be hoped for and STRONG
Sunday Driver likes this.
Tommays
Northport NY
Old 11-18-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
Nice job - very tidy. The painted area is why trim was invented anyway.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Old 11-20-2011
paulk's Avatar
paulk is on a distinguished road
If the damage is cosmetic, you can cut out the section and glue a matching (that's the fun part-possibly why Tommay's painted his...) veneer over it. Otherwise, Tommay's route is the way to go. His "taping back to the hull" is a nice way of saying "maybe a day or so of prep and another two to three episodes of layering reluctant fiberglass and noxious chemicals to join everything in a strong bond that looks presentable". His looks great! Good luck.
Black Rot Spot on Teak Bulkhead Repair dougshipl Gear & Maintenance 6 04-20-2010 07:36 PM
Chain Plate Bulkhead Repair Islander30Bahama Gear & Maintenance 4 03-27-2009 07:06 PM
Bulkhead Confusion RichP Sailboat Design and Construction 10 11-08-2008 03:49 PM
Bulkhead repair......ive put this off long enough. SVDistantStar Gear & Maintenance 3 08-29-2008 12:58 AM
bulkhead repair olepedersen@yahoo.com Irwin 0 04-15-2006 08:12 AM
