Like Tree1Likes
Old 11-22-2011
ccriders is on a distinguished road
Antifouling Paint
I have to clean and repaint the bottom of my boat. I estimate that I will need one and a half gallons of paint. A gallon and two quarts costs more that two gallons, so I will buy two gallons. So what should I do with the extra half gallon? Go ahead and apply it to the hull, save it for next time, give it to someone or dump it?
John
Old 11-22-2011
sfchallenger is on a distinguished road
Extra coats won't hurt, I'd put it all on the hull. Next time I do mine I'll do more than one coat, it's shocking how fast it wears off - I changed colour when I did mine so it's easy to see wear.
Don't dump it if you don't use it, dispose of it properly.
Sailing a '74 Challenger 40' Ketch rig out of San Francisco
Old 11-22-2011
AboardIndigo's Avatar
Seen Your Mamba
AboardIndigo is on a distinguished road
I would save it. You never know when you might need to touch up or help a dock-mate out with your extra.
Indigo
1976 Catalina Yachts C-22
Old 11-22-2011
b40Ibis is on a distinguished road
Can you use the rest on the dink?
Old 11-22-2011
SloopJonB's Avatar
Senior Moment Member
SloopJonB will become famous soon enough
John
Use it - put extra coats on the high wear areas like the front of the keel, along the waterline etc. until you run out.
killarney_sailor likes this.
"There is nothing, absolutely nothing, half so much worth doing as simply messing about in boats". The Water Rat from The Wind In The Willows
Sailing for 40 years in the Pacific, Atlantic, Caribbean but mostly Georgia Straight.
Currently own a Columbia 43.
Old 11-22-2011
chef2sail's Avatar
C&C Racer/ Cruiser
chef2sail is on a distinguished road
At 200 per gallon why wouldnt you save it. We put two coats on of Ultima 60...one red and one blue...we can see how it is wearing. Extra on the leading edges of the keel and rudder.
dave
___________________________
S/V Haleakula (Hawaiian for" House of the Sun")
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Old 11-23-2011
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
How many coats will a 1.5 gallons buy you? As previously mentioned, more is better. 2 coats on the hull, 3 at the waterline and leading & trailing edges. If there's any extra after that, put it on the boat. You will stretch the time between haulouts.
You tell me what that's worth.
"Clean bottoms are FastBottoms"
Old 11-23-2011
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
Most of the growth onthe hhull last summer was within 2 feet of the waterline.
Before launching yesterday, I put and extra coat in that location. Sanding barnacles is a real bear. their "roots" go way down into the gel coat.
Just keep going around until you use it up. As someone said, "It doesn't expire".
Regards,
Brad
Old 11-25-2011
Thanks everyone,
Two gallons will give me two layers overall and as recommended three coats around waterline and leading edges. Sounds like a good plan.
So, as a follow-on, should I use the expensive stuff - Petit Trinidad SR - or the less expensive West Marine product? The marina waters, at about 85 degrees in the summer, in Corpus can grow stuff quite rapidly and I would really like to get two or more years between haul outs.
John
Old 11-25-2011
Fstbttms's Avatar
Thanks everyone,
John
As far as I can tell, West Marine no longer carries a house brand modified epoxy paint that is the equivalent of Trinidad. My suggestion is to use Trinidad and have the bottom cleaned relatively frequently. This will significantly lengthen the useful life of the paint.
Removing antifouling paint Badfish Gear & Maintenance 14 03-05-2011 08:16 PM
Barrier Coat & Antifouling paint shipley Gear & Maintenance 7 08-09-2009 09:18 AM
Do all boats need antifouling bottom paint? AllThumbs Gear & Maintenance 14 02-03-2009 02:08 PM
Anti Graffiti Paint for Antifouling xuraax Gear & Maintenance 2 01-31-2009 06:48 AM
antifouling? Mick Young Gear & Maintenance 4 11-16-2006 06:31 PM
