11-23-2011
Originally Posted by rikhall
We have:
Irwin Citation 34, LOA: 34' 3", LWL: 27' 4", Beam: 11' 3" Displacement: 11500 but weight at launch is about 1300. Yanmar 2QM20H Rated RPM: 3800 / Rated HP: 20 / Gear Ratio: 2.14
Propeller is a cracked 14x10 RH three blade on a 7/8 inch shaft. With it we get: 2100 RPM - about 5.2 KN
2600 RPM - about 6.0 KN Hull speed "should be" about 7 KN
One propeller manufacturer is recommending a 14x9. Would not a 14x9 give me less speed and perhaps a 14x11 give me a bit more????
Also - I will also happily take any recommendations for places to purchase a new or used appropriate prop.
Rik
 Don't get insulted, but I believe that your boat's shaft is undersized... For that HP and displ. a one inch shaft would seem more appropriate. But, that's not what you asked...
Our boat is a 34' that weighs in at about 11K, and has a 23 hp diesel, and we use a three blade 15 X 9.5. This is still a tad over-propped and a 9" pitch would be better. I can motor at 7.2 in smooth water with a clean bottom.
My current prop is a Michigan "Sailor" and was out of pitch on one blade when delivered. If you go with that brand, have the prop precision-checked when you receive it. (Had I known that their QC was so hit-n-miss I would have gone with another brand.)
Having said that, the three blade fixed can now drive our boat at full speed thru a moderate chop.
Check your motor specs and see what rpm that Yanmar recommends for sustained cruising - I bet that it's more like 2900 or so. Pitch your new prop for that rpm. At the present 2600 rpm, you are likely only achieving about 15 hp, and that's not much help to get you thru a chop.
L
