Blogs
User Name
Old 09-24-2003
svzephyr44 svzephyr44 is offline
svzephyr44 is on a distinguished road
Rust Removal from Tools
I have a large, and I mean large quantity of tools and assorted small parts that all have a light coating of rust. Is there some simple way (like putting them in a bath of some solvent) to clean them up?
Old 09-24-2003
hamiam hamiam is offline
hamiam is on a distinguished road
I have not tried this myself but I was told that if you soak tools in coca-cola over night the acid in the soda will actually remove the rust. Sounds crazy but its worth a try.
Old 09-24-2003
RichH RichH is offline
RichH is on a distinguished road
Boiling in water for a moderately long time will remove surface rust and form ferrous oxide - the ''good'' rust.
Add a bit of phosphoric acid to the boiling water and you will quicken the reaction.
Coating with a ''rust reformer'' containing phosphoric acid is the best method of rust removal: Ospho, Naval Jelly, etc. BoatUS, WestMarine, etc. supply spray on ''rust reformers''.
Any method that converts ferric oxide to ferrous oxide will work. The ferrous oxide is the ''blue'' sheen on guns, etc. used to protect against ferric oxide formation.
Coke, Pepsi, etc. contain phosphoric acid but not enough to make much difference, .... unless you *boil* the part in them.
Sponsored Ad
Display Modes
vB code is On
Teak Deck Removal petermac Gear & Maintenance 7 01-10-2008 03:13 PM
Tiny rust spots from nearby grinders VIEXILE Gear & Maintenance 7 04-09-2004 06:22 AM
rust in non metallic sinks c2cSailor Gear & Maintenance 3 08-21-2003 05:04 PM
rust on keel gregreinhard Gear & Maintenance 1 01-20-2003 03:08 AM
Sail Rust Stain Removal davidusvi Gear & Maintenance 2 02-06-2002 04:59 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
